If you own a Bosch Axial Glide Miter Saw, add this flap:
Forum topic by Keith Kelly posted 06-21-2019 04:10 PM 1095 views 0 times favorited 7 replies Add to Favorites Watch
View Keith Kelly's profile
Keith Kelly
340 posts in 2670 days
06-21-2019 04:10 PM
I set up lights & cameras to visualize dust flow, and found a disconcerting ricochet happening on the flat edge of the dust port. Problems caused:
  • When cutting thicker stock, the dust ricochets back downward.
  • When cutting any stock, the flat edge causes air turbulence around the dust entry area (presumably)
Adding the flap does not interfere with any movement of the saw.
Video:
https://www.youtube.com/watch?v=iDQSWgTmGFo
Flap:
I have the GCM12SD. I expect the CM10GD would be built the same way, but the dust may follow a different path and contact with a different thickness of wood.
I’m posting this on two forums. If that’s breaking some sort of etiquette, let me know.
-- Keith | Subscribe: https://www.youtube.com/c/KeithsTestGarage
7 replies so far
View Aj2's profile
Aj2
3663 posts in 2805 days
#1 posted 06-21-2019 04:45 PM
I’ll try the little flappy thing. The plastic thing that came with the saw broke on my saw very early.
I added a piece of lead that works pretty good it will take a good hit from cut off pieces.
Thanks for the tips.
-- Aj
Keith Kelly
#2 posted 06-21-2019 04:47 PM
I ll try the little flappy thing. The plastic thing that came with the saw broke on my saw very early.
- Aj2
Lead?
View Aj2's profile
Aj2
#3 posted 06-21-2019 05:33 PM
Ya,Metal that’s soft Lead.
-- Aj
Keith Kelly
#4 posted 06-21-2019 06:11 PM
- Aj2
Interesting. I have never seen it used like that.
runswithscissors
3128 posts in 3032 days
#5 posted 06-24-2019 04:22 AM
Sheet lead is used for flashing around chimneys (and other things).
Keith Kelly
#6 posted 06-24-2019 04:28 AM
It makes sense… the properties/workability/conductivity are unique. My first thought was “isn’t lead dangerous?” and then I realized that half the stuff I use is dangerous….and that’s why we use the appropriate safety measures for whatever we’re working with.
Definitely tucking that in the back of my mind. Thanks for the tip.
View TungOil's profile
TungOil
1383 posts in 1502 days
#7 posted 06-24-2019 06:37 AM
I made mine from some heavy rubber sheet
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
