Tablesaw blade recomendations?
Forum topic by Jim55 posted 06-20-2019 07:11 PM 509 views 0 times favorited 8 replies Add to Favorites Watch
View Jim55's profile
Jim55
187 posts in 2833 days
06-20-2019 07:11 PM
Hello. My table saw uses a typical 10” blade. What I have is a situation where I want to rip a number of weathered oak 4”x4”s. I would like some blade recommendations. Not so much brands, we all have our favorites. But specific tooth count, configurations and/or features that will aid in this specific endeavor.
I am not opposed to brand recommendations but lets restrict those to features specific to this job that other brands may not have.
Ok?
Priced under $100 and preferably under $50 if an option.
Thanks to all!
8 replies so far
View PPK's profile
PPK
1746 posts in 1576 days
#1 posted 06-20-2019 07:16 PM
Cheap 24 tooth rip blade. Can be had for about $25. I think the one I have is by CMT. Thin kerf or full kerf, it doesn’t matter all that much. If you don’t like deflection, then full is better, if you don’t like wasting as much lumber/have a lesser-powered saw, then thin kerf is for you. Don’t waste your money on expensive blades that may easily get ruined in one second by a hidden nail or embedded rock or whatever. That’s my two cents!
-- Pete
View HokieKen's profile
HokieKen
13973 posts in 1905 days
#2 posted 06-20-2019 07:23 PM
I agree. If these are old Oak 4×4s, I would buy a “beater” blade for ripping them. There’s a good chance you may chip a tooth or two. Fewer teeth is better. Full kerf unless your saw just doesn’t have the “umph” then you may need to try a thin kerf. Also, check the actual dimensions of the 4×4s and the max cut capacity of your saw. Depending on your saw, you may have to make the cuts in two passes. Which doesn’t really affect blade choice but thought I’d throw it out there.
If it were me, I’d grab a Harbor Freight rip blade. Cheap but capable blade and I wouldn’t feel bad about trashing it if I hit a nail or something and broke a tooth or two.
-- Kenny, SW VA, Go Hokies!!!
View Nubsnstubs's profile
Nubsnstubs
1723 posts in 2497 days
#3 posted 06-20-2019 07:50 PM
What Kenny says. The two passes should be made with an eighth inch above center if your saw doesn’t have a lot of power. That would be 1 7/8” blade height if the wood is 3 1/2”........... Jerry (in Tucson)
View knotscott's profile
knotscott
8382 posts in 4142 days
#4 posted 06-20-2019 10:05 PM
Hard to go wrong with a $28 Freud Diablo 24T TK blade for this task.
View farmfromkansas's profile
farmfromkansas
182 posts in 381 days
#5 posted 06-21-2019 01:07 AM
Last black friday sale Menards had a 10” set of cmt blades, a 24 tooth rip blade, and a 60 tooth crosscut blade, thin kerf way cheap. I got 3 pairs. CMT makes good blades too.
View PPK's profile
PPK
#6 posted 06-21-2019 12:51 PM
- farmfromkansas
Yup, pretty sure that’s what I bought. the 60t crosscut works great on my chopsaw.
-- Pete
View HardKnockCarpentry's profile
HardKnockCarpentry
21 posts in 542 days
#7 posted 06-22-2019 08:46 PM
If you’re looking for a reasonably priced blade for ripping oak timber, get a Mamba. They are around $25-$40 on Amazon. They absolutely rip through oak beams.
View Jack Lewis's profile
Jack Lewis
576 posts in 1845 days
#8 posted 06-22-2019 09:02 PM
You failed to state what the end use of the Oak is to be. What degree of finish is acceptable? Glue joints, furniture, fence posts??
-- "PLUMBER'S BUTT! Get over it, everybody has one"
