need chainsaw help
Forum topic by Karda posted 06-18-2019 04:47 AM 434 views 0 times favorited 11 replies Add to Favorites Watch
View Karda's profile
Karda
2532 posts in 1437 days
06-18-2019 04:47 AM
Hi, I started sharpening my own chain saw. However it is electric and the chain is almost impossible to advance by hand but it will go backwards easily. What can I do to get the chain out so I can sharpen on the machine thanks
11 replies so far
View MrUnix's profile
MrUnix
8240 posts in 3082 days
#1 posted 06-18-2019 05:05 AM
I don’t use a machine, just a round file with a guide to sharpen. However, to your question… it seems like if the chain will turn one way easily, and hard the other, then you would just sharpen in the direction that it turns easily. Otherwise, take the chain off to sharpen – should just need to remove the bar nuts.
Karda
#2 posted 06-18-2019 06:04 AM
will moving the chain backward damage the saw, how would you hand sharpen the chain off the bar
MrUnix
#3 posted 06-18-2019 06:12 AM
- Karda
I can’t imagine why moving the chain backwards would hurt anything… unless the manual says something like “DO NOT TURN BACKWARDS” in big red letters :)
As for sharpening off the saw – depends on the sharpening system you have (and you did ask how to ‘get the chain out’ to sharpen).
Karda
#4 posted 06-18-2019 06:19 AM
get the chain out was a poor choice of words. What i want is to be able to move the chain along the bar without a tug of war. I am sharpening with a file
View OSU55's profile
OSU55
2658 posts in 2873 days
#5 posted 06-18-2019 11:59 AM
Chain lubed well? Just loosen the chain tensioner some and see if that helps. If not, as Brad said rotate it backwards.
View Lazyman's profile
Lazyman
5864 posts in 2270 days
#6 posted 06-18-2019 12:19 PM
As long as there is no grinding noise (as in a gear teeth not engaging properly) when you move the chain backwards it should be fine. It probably has at least one plastic gear so you don’t want to put any more wear on it than necessary. Just make sure that’s not why you can move it backwards more easily than forward. You should be able to see the motor turn inside the housing as it moves.
View bilyo's profile
bilyo
1167 posts in 1986 days
#7 posted 06-18-2019 02:42 PM
Some one correct me if I’m wrong. I would be reluctant to sharpen the chain while it is still on the bar for fear of getting fillings into the groove that the chain slides in. I can’t imagine that that would be a good thing.
View Kirk650's profile
Kirk650
680 posts in 1631 days
#8 posted 06-18-2019 03:02 PM
Many folks sharpen the chain while it’s on the bar, professionals included, so I don’t think you need to worry about the filings.
I just sharpened a chain yesterday, after dulling it on Oak. I use an electric sharpener, this being the second one. Wore the first one out. Prior to that I used a file, but it was too slow if I had more than one chain. Even the $30 electric sharpener at Harbor Freight works good if used properly. That’s what I started with and finally wore out. Now I have a more expensive unit.
If a fellow has one chainsaw and rarely uses it, then sharpening by file is all he needs. That said, the HF sharpener is worth the $30.
View Nubsnstubs's profile
Nubsnstubs
1732 posts in 2613 days
#9 posted 06-18-2019 03:19 PM
Stihl makes jigs for sharpening chains on the bar. It’s the only way the jig will work. It’s ok to sharpen on the bar.
Brad and others, that “DO NOT TURN BACKWARDS” in big red letters :) might actually mean, Do not install the chain backwards. It looks like it could actually happen if the chain is stretched.
I don’t know for sure, but I seriously doubt an electric chain saw would have a plastic sprocket….... ......... Jerry (in Tucson)...... ......... Jerry (in Tucson)
Lazyman
#10 posted 06-18-2019 08:44 PM
I don t know for sure, but I seriously doubt an electric chain saw would have a plastic sprocket….... ......... Jerry (in Tucson)...... ......... Jerry (in Tucson)
- Nubsnstubs
That was the voice of experience Jerry. Here’s what happens when something goes wrong. Note how the teeth are basically gone. Not sure what made it do this exactly but the motor shaft had a metal gear and on the other side of this sprocket is what drives the chain. It appears to have some sort of glass or carbon fiber in it but it is definitely some sort of molded plastic.
Karda
#11 posted 06-19-2019 01:57 AM
the chain has been hard to pull forward from the time it was new, thats the way it is. I looden the chain that helped
