1hp Leeson motor
Forum topic by Mattfinisher posted 06-17-2019 09:35 PM 580 views 0 times favorited 6 replies Add to Favorites Watch
View Mattfinisher's profile
Mattfinisher
75 posts in 3335 days
06-17-2019 09:35 PM
Just moved to a new space that is not equiped with 220. So I found a 1hp leeson electric motor 3450 rpm wired for 110. Put in on my table saw (old delta/rockwell contractor 12) and now I cant cut warm butter. Any one have any suggestions as what I can do to utilize the 110 in my shop? Any help is appreciated!
-- “Anyone who doesn’t think money is grown on trees hasn’t bought any lumber lately.” www.facebook.com/johnsonandsons72
View MrUnix's profile
MrUnix
8985 posts in 3649 days
#1 posted 06-17-2019 09:42 PM
Do you have it spinning the right way?
View Chris_Tx's profile
Chris_Tx
30 posts in 1181 days
#2 posted 06-17-2019 10:13 PM
Pretty much all of my equipment runs on 110. I only have one 220 outlet in my shop. Maybe you could tell us what the problem seems to be? Like Brad says, are you sure it is turning the right direction?
Mattfinisher
#3 posted 06-17-2019 11:00 PM
Yes it’s turning in the right direction. It cuts, but just bogs down to the point of the blade stopping. Even cutting 1/2” ash.
MrUnix
#4 posted 06-17-2019 11:09 PM
Sounds like it’s wired for 240v. Those are the symptoms of a 240v motor running on 120v. Does it spin up fast or take some time? If it’s a dual voltage motor, then double check the wiring.
Mattfinisher
#5 posted 06-17-2019 11:46 PM
Thanks Brad! Im gonna try that! You are probably correct!
Mattfinisher
#6 posted 06-18-2019 12:49 AM
Brad! You are the man! Just ripped thru some 4/4 cherry like it was nothing! Thanks again!
