Cabinet assembly workstation
Forum topic by MGildersleeve posted 06-16-2019 01:44 AM 406 views 0 times favorited 1 reply Add to Favorites Watch
View MGildersleeve's profile
MGildersleeve
5 posts in 135 days
06-16-2019 01:44 AM
Topic tags/keywords: jig tip cabinet assembly assembly jig workbench
I started as a cabinet maker for a mid level shop a couple months ago. There’s a lot of standards, enough to allow for a jig I’ve been trying to wrap my head around for some time. Before I was working in a very high end custom shop, not so standard. The main idea of this jig is to hold cabinet pieces for assembly as one assembles the cabinets on their sides, allowing for easier use of drills and staplers. Also, it is mobile with an accompanying parts cart. This allows the assembler to roll the parts and the workstation directly to the staging area and off load the cabinets where they will sit to wait for finishing, which is much less lifting. This system has already broken the production record of the shop. There’s some other carts and racks systems being developed to quicken the cutting process. Saving time is money in the pocket.
Here’s a video that shows the action:
https://youtu.be/aTZRB6FSYLo
1 reply so far
View therealSteveN's profile
therealSteveN
3910 posts in 1087 days
#1 posted 07-05-2019 04:01 AM
In a standardized situation that is a rock star. As you said not so much for customs. I wonder if a guy was just making his own kitchen if the build would be worth the time? There are so many work holding clamps, corners, and other means of supporting the sides as you build out, kind of a push shove thing here. Resonates better in a place a lot of cabinets are made, and all pretty standard sized.
-- Think safe, be safe
