I stained over glue and it left a blotch.. Doh!
Forum topic by Pageplayer posted 06-09-2019 07:55 PM 661 views 0 times favorited 8 replies Add to Favorites Watch
View Pageplayer's profile
Pageplayer
14 posts in 374 days
06-09-2019 07:55 PM
I laid some fiddleback veneer over an old stereo receiver case. There was a chipped area in the veneer near a edge that I had cut out and glued in a replacement piece, and filled in any micro voids with “stainable” wood filler.
But I apparently did not sand off enough of the residual glue or wood filler because now I have an ugly blotch in that area after staining.
Whats the best way to fix this?
I’m hoping I don’t have to rip off the veneer.
8 replies so far
View cracknpop's profile
cracknpop
350 posts in 2771 days
#1 posted 06-09-2019 08:03 PM
Post a picture or two so we can see what you describing.
-- Rick - I know I am not perfect, but I will keep pressing on toward the goal of becoming all I am called to be.
Pageplayer
#2 posted 06-09-2019 08:11 PM
Not sure how to post here, but here’s a link to Dropbox.. (no account needed)
https://www.dropbox.com/s/rh2ca3ua42y0rfl/20190609_153702.jpg?dl=0
cracknpop
#3 posted 06-09-2019 08:26 PM
Post a picture here by clicking the “img” button just above where you type. Click “Choose File” to browse your device to select the image. Then click “Insert this image”.
Pageplayer
#4 posted 06-09-2019 08:53 PM
View shipwright's profile
shipwright
8320 posts in 3220 days
#5 posted 06-10-2019 05:16 AM
Can’t help you with this one unless the veneer is thick enough to sand through the glue residue but I can tell you how to not have it happen again.
Use hide glue, either hot or liquid. If you had, the answer here would be simply to give the area a light scrub with cool water.
View Rich's profile
Rich
4579 posts in 1012 days
#6 posted 06-10-2019 05:59 AM
With some Prismacolor pencils and a little patience, you can recreate that grain pattern, topcoat it and you’re done.
-- Knowledge is not skill. Knowledge plus ten thousand times is skill. -- Shinichi Suzuki
Pageplayer
#7 posted 06-10-2019 10:52 AM
Lesson learned.. Thanks to all.
Pageplayer
#8 posted 06-10-2019 10:59 AM
One more question..
What is the best way to sand (prep finish) for staining figured veneer, as far as sanding direction.
I know usually with the grain.
