Shopping for leg vise hardware
« back to Hand Tools forum
Forum topic by Rhaugs posted 06-08-2019 02:10 AM 562 views 0 times favorited 10 replies Add to Favorites Watch
View Rhaugs's profile
Rhaugs
18 posts in 545 days
06-08-2019 02:10 AM
Hi All,
Shopping for leg vise hardware.. I am trying to find a Yost leg screw, but they don’t seem to make them anymore. Does anyone have a good alternative to these?
10 replies so far
View SMP's profile
SMP
2128 posts in 682 days
#1 posted 06-08-2019 03:37 AM
You can just use the 18” vise screw.
Rhaugs
#2 posted 06-08-2019 03:52 AM
- SMP
That’s what they don’t have
View SMP's profile
SMP
#3 posted 06-08-2019 04:48 AM
- SMP
That s what they don t have
- Rhaugs
Aww bummer, because the Woodcraft branded one is $80. Lee valley has it in a different color for bot much more than the yost:
http://www.leevalley.com/us/wood/page.aspx?p=41664
And the Shopfox one is basically the same except the handle:
https://www.amazon.com/Shop-Fox-D3258-Bench-Screw/dp/B00012XCCA/ref=pd_aw_sbs_328_3/132-0072633-6147463?_encoding=UTF8&pd_rd_i=B00012XCCA&pd_rd_r=07894bf8-89a8-11e9-8d2e-a70b2f04bb3c&pd_rd_w=WBU1V&pd_rd_wg=Rpxia&pf_rd_p=aae79475-6dc9-4a12-80e8-27b63108fa72&pf_rd_r=0W94CZBHM0CZ44WXBKZC&psc=1&refRID=0W94CZBHM0CZ44WXBKZC
View Rayne's profile
Rayne
1312 posts in 2316 days
#4 posted 06-08-2019 12:07 PM
- SMP
- Rhaugs
- SMP
I bought the ShopFox version with plans to use an angle grinder to cut handle off. You should be able to do the same and keep the cost down.
Rhaugs
#5 posted 06-08-2019 06:24 PM
- Rayne
So how would you attach a new, wooden handle
View bondogaposis's profile
bondogaposis
5791 posts in 3127 days
#6 posted 06-08-2019 07:05 PM
Just buy some Acme thread rod and a nut from McMaster-Carr.
-- Bondo Gaposis
Rayne
#7 posted 06-08-2019 10:05 PM
- Rayne
- Rhaugs
Just drill a hole in the center of one of the end caps and screw it in after sliding it in the hole. But I might not go with a wooden handle on this particular one because the hole is small so you may not have enough torque before the handle breaks. I have a handwheel I got used a while back. Gonna see if I can drill and tap the end of the screw to attach the handle to it or some other, similar method to secure it. I’m not at that stage just yet, but I do have all the hardware to make the vise right now.
View SMP's profile
SMP
#8 posted 06-08-2019 10:10 PM
- bondogaposis
I looked at doing that before buying my last one. After buying the threaded rod and nut from different places, trying to source something for the handle/wheel, and then trying to jry rig it all together, it was actually cheaper to buy one of the ready made ones and WAY less work and possibilities of things going wrong.
View dscheidt's profile
dscheidt
33 posts in 396 days
#9 posted 06-13-2019 04:10 AM
I asked Yost, and they say new stock is in transit, and should be available in July.
View HokieKen's profile
HokieKen
14070 posts in 1914 days
#10 posted 06-13-2019 01:35 PM
- SMP
The Shopfox isn’t really as well-suited because it doesn’t have a garter to attach to the chop. So you’d have to fabricate and attach one of those. I used the Lee Valley tail vise screw for my leg vise and it works wonderfully.
-- Kenny, SW VA, Go Hokies!!!
