New to scrolling
« back to Scrollsawing forum
Forum topic by MrRon posted 06-03-2019 11:54 PM 917 views 1 time favorited 8 replies Add to Favorites Watch
View MrRon's profile
MrRon
5975 posts in 4218 days
06-03-2019 11:54 PM
Topic tags/keywords: question
I have all the tools in my shop except a scroll saw. So I went and bought a Wen scroll saw. It is a clone for many other scroll saws including HF. Overall, I like the saw, but one thing bothers me and I don’t know if it is typical of all scroll saws. I was sawing some 1/2” wood and I have a hard time holding the wood down to the table. I removed the hold down foot so I could get a better view of the cut line. Even with the hold down installed, the wood still bounces up and down. Is this common of all scroll saws? At low speed, the work doesn’t bounce around as much as at high speed. Is there a technique to scroll sawing I’m not aware of? With the type of projects I do (large scale train models), a scroll saw is a very useful tool.
8 replies so far
View wichman3's profile
wichman3
99 posts in 1595 days
#1 posted 06-04-2019 12:15 AM
You probably have the blade installed upside down. Try again after flipping the blade. :)
View Redoak49's profile
Redoak49
5026 posts in 2963 days
#2 posted 06-04-2019 01:54 AM
A typical newbie problem is choosing the right blade and installing it properly.
You might tell us what blade you are using.
View ibewjon's profile
ibewjon
2224 posts in 3768 days
#3 posted 06-04-2019 02:30 AM
Some blades cut on the down stroke, and some on both up and down.
View JRsgarage's profile
JRsgarage
389 posts in 1484 days
#4 posted 06-04-2019 02:34 AM
I think it is kind of normal to some degree. If the blade is properly installed, I’d check the tension. And just practice…remember like a jig saw, let the blade do the cutting.
Those saws seem to have decent reviews as most Wen tools.
-- “Facts don't care about your feelings.” ..., Ben Shapiro
View PaulDoug's profile
PaulDoug
2442 posts in 2678 days
#5 posted 06-04-2019 03:50 AM
If you are new to scrolling a great very active forum for scrollers is scrollsawvillage.com. Great group of people that are very willing to help. Not that you won’t get help here but that site is 90% just about scrolling. There is a lot more to learn about scrolling than just putting a blade in a scroll saw and going at it. There are many blade in many sizes and configurations each with their purpose. There are different types of scrolling from portrait, to 3D pieces, to bowls and vases, to seashells and puzzles, then there is model making…...
But be careful, like you it was just another tool in the shop… but the more I learned about it the more I became hooked. Now, I spend more time with it than any other tool in my shop!
View Davevand's profile
Davevand
231 posts in 1811 days
#6 posted 06-04-2019 03:01 PM
As others have asked, what type of blade and what vendor blades are you using. All blades should have some kind of indicator as to which way is up. If you are using cheap blades, toss them and get some good ones, I use Flying Dutchman and Pegas blades. No matter what blade, if you try to cut too fast the work piece will want to jump around, slow and steady is the best way to cut.
View cowboyup3371's profile (online now)
cowboyup3371
187 posts in 1172 days
#7 posted 06-05-2019 10:57 PM
I have also learned the slower I push the wood through and the more I left the blade do the work the less it bounces on me
-- Cowboy Up or Quit - If you are going to quit than get out of my way
View Jim Finn's profile
Jim Finn
2866 posts in 3896 days
#8 posted 06-09-2019 07:03 PM
Yes slow feed rate and lots of downward pressure on the wood will help this problem a lot. The scroll saw is absolutely the slowest cutting saw in a workshop. Take your time with it. Remember that the cut with a scroll saw is the best , smoothest cut of any saw so there is no sanding necessary of that cut in solid wood. It is like you are cutting and sanding at the same time.
-- No PHD just a DD214 Lubbock Texas
