DW 733
Forum topic by Eloyd posted 05-30-2019 06:17 AM 348 views 0 times favorited 5 replies Add to Favorites Watch
View Eloyd's profile
Eloyd
33 posts in 1878 days
05-30-2019 06:17 AM
I have a DeWalt thickness planer, model DW-733. I have had it for 10-15 years, and it works great. However, I am noticing that when I turn the crank down, it works o.k., but when I turn the crank up, it makes grinding noises, and is hard to turn. I usually have to block the base, and use both hands to turn it. I removed the cover housing to see if I could see any visible problem, but all looks as I think it should look. Anyone else have this planner and have this problem?
-- Eloyd
5 replies so far
View Bill White's profile
Bill White
5225 posts in 4444 days
#1 posted 05-30-2019 01:50 PM
Have you given the columns a good cleaning?
-- [email protected]
View sepeck's profile
sepeck
402 posts in 2625 days
#2 posted 05-30-2019 03:46 PM
I do, but haven’t had the time to put it on the bench to take apart yet. It goes down but won’t come up. Hopefully I will be able to put it on the bench this weekend and look at it since I got my wife’s project done this week. I had just about saved up for a bench top 8” jointer too, so I’d rather not have to replace the planer instead :)
If I can get mine taken apart this weekend, I’ll post a reply unless someone beats me with a better solution.
This is not the same issue, but has a great set of instructions in the replies on assembly/disassembly
https://www.lumberjocks.com/topics/15447
-- -Steven Peck, http://www.blkmtn.org
View GR8HUNTER's profile
GR8HUNTER
6384 posts in 1196 days
#3 posted 05-31-2019 02:23 PM
- Bill White
+1 i have delta same problem cleaned them up real good now it glides like hot knife through butter :<))))
View bilyo's profile
bilyo
826 posts in 1586 days
#4 posted 05-31-2019 03:01 PM
Yes. Clean/lube the columns. and lube the screws. Also, check to see if the break is dragging for some reason. No need to take anything apart to do these things.
View fivecodys's profile
fivecodys
1470 posts in 2120 days
#5 posted 05-31-2019 03:18 PM
Mine was doing the same thing.
I gave everything a good cleaning and then used WD40 Lock Lube and man what a difference!
I sprayed it on the big screw and also the scissor bracket in the center.
Make sure you cover the bed of the planner because you don’t want this stuff to find its way onto your boards.
-- When you leave your shop for the night, make sure you can always count to 10.
