05-26-2019 09:18 PM
I recently restored a 1952 Rockwell Homecraft 10” bandsaw. After restoring it, I installed a blade and made several cuts with it. It was running fine and I was happy until the blade snapped. I ordered a new blade, but couldn’t get it to tension near enough (I had over an inch of play in the blade). After checking that the new blade was the correct length and comparing it to the blade that snapped, I was convinced that the problem wasn’t the blade. When I tightened the tensioning knob, the spring completely bottomed out. I figured that the spring lost its “springiness” for lack of better terms so I got a hold of Louis Iturra, who the internet tells me is the absolute authority in all things old bandsaws. He confirmed that the problem just might be the spring. I ordered up a new high-tension spring from him. After installing the new spring, I was still unable to tension the blade. That’s when I noticed that the tracking adjustment screw was preventing me from fully raising the sliding bracket for the upper wheel. There’s a channel in the mounting plate for that bracket which allows the tracking screw to pass through it so that it can engage the bracket and adjust the angle of the wheel. That channel is not long enough for the screw to pass through for some reason.
Here’s a picture: http://i.imgur.com/2FBdvFB.jpg
The part on the bottom with the two bolts is the mounting plate and the upper part is the sliding bracket. You can see the channel for the tracking screw and the hole that the screw is supposed to go through, but can’t. Essentially, that channel is ~3/16” too short for the tracking screw to pass through if the blade was fully tensioned.
Now as I said, I was able to use this saw before with the same sized blade but now I can’t any more. I checked the mounting plate with a straight edge and it isn’t bent, it’s almost as if it has shrunk. The only thing I can think of is that the upper frame arm has bent, but it’s cast iron, that seems unlikely.
I’d appreciate any input as to what has happened to my bandsaw. Thanks.
Video explaining the problem: https://youtu.be/URaSvVfsrQc
9 replies so far
#1 posted 05-26-2019 11:18 PM
Sounds like the blade is too long… what size is it? Should be 71-3/4” but you can usually get away with almost an inch +/-
Cheers, Brad
#2 posted 05-27-2019 07:15 AM
I did check the blade length, both with a rule and against the blade that snapped. It is 71 3/4”.
#3 posted 05-27-2019 10:59 AM
May be the problem is on the lower wheel. The upper wheel bracket looks fine.
-- Bruce, Boise, ID
#4 posted 05-27-2019 11:02 AM
Did you put new tires on that are thinner than the original? One thing is the spring should not be bottomed out, that can break blades. I say get a 1/4 – 1/2” shorter blade.
#5 posted 05-27-2019 12:41 PM
There’s no play in the lower wheel’s axle and it hasn’t bent.
I did put new tires on the saw, but that was before either blade went on, the last blade fit fine. The problem is that something seems to have happened to the saw which no longer allows the new blade to fit.
#6 posted 05-28-2019 11:06 AM
When you say you restored it, what does that mean? Is it possible that in the process you got a part installed upside down or incorrectly which is not allowing the tensioner to work correctly? The clue is that the tracking screw is interfering…. I know nothing about the machine so I couldn’t say for sure, just guessing.
-- Jim, Georgia, USA
#7 posted 05-28-2019 05:26 PM
Jim, it was a complete rebuild; disassembly, clean, reassemble. I was able to get the saw to run after the restoration, though.
#8 posted 05-28-2019 06:43 PM
I have been following this with interest to see what the cause of the problem might be. My initial thought, after seeing the video, was like other comments above that there might be an issue with the mounting of the lower wheel. You didn’t have any parts left over after the reassembly did you? (Just kidding).
A Google search turned up an old Lumberjocks post about a similar restoration.
https://www.lumberjocks.com/timbit2006/blog/29142
In that thread is a link to another Lumberjocks blog post made by EEngineer eight years ago.
https://www.lumberjocks.com/projects/51845
The author of the first link hasn’t been active for many years, but EEngineer last posted here back in February, but he might still be active. You might try sending him a message.
#9 posted 05-28-2019 06:55 PM
About the new tires. In your video it sure looks like the tire fits way down in the groove on the pulley. It wouldn’t take too much change in the thickness of the tires to make a significant impact on the circumference of the pulley. Perhaps the tires were not fully seated at first and you could sort of tension the original blade. After running the saw a bit the tires might have seated further and the blade became very loose and eventually snapped. Now the new blade doesn’t fit either. The fact that the first blade snapped might be a clue.
Just a wild and crazy idea, but other than that I don’t know what else to suggest.
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
13240 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2830 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
578 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
417 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1914 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
6397 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
7940 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
32939 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
334 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
6487 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1825 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
7309 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1647 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2644 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1273 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
5436 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2401 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
9685 |
