SketchUp Layers
Forum topic by Horus posted 05-23-2019 06:06 PM 238 views 0 times favorited 11 replies Add to Favorites Watch
View Horus's profile
Horus
39 posts in 57 days
05-23-2019 06:06 PM
Hi all.
I’m using a free version of SketchUp Make and can’t figure out how to turn on (or access) the layers function. It’s possible this feature isn’t available int he free version; but, it looks like it should be from what I’ve read online.
Any suggestions? I really like this program, it does what I need it to do, and the price is right.
Also, I have not figured out how to make a cylinder yet – for dowels or holes.
Thanks.
11 replies so far
View ScottM's profile
ScottM
736 posts in 2535 days
#1 posted 05-23-2019 06:24 PM
Define “free version”. Do you mean the web-based/browser version or an older version of Sketchup Make?
Horus
39 posts in 57 days
#2 posted 05-23-2019 06:29 PM
- ScottM
I’m using Sketchup Make v 17.2.2555
View SMP's profile
SMP
1041 posts in 294 days
#3 posted 05-23-2019 06:30 PM
what browser are you using? An do you have several browsers installed?
Horus
39 posts in 57 days
#4 posted 05-23-2019 06:33 PM
- SMP
I normally run Firefox, I have Chrome and IE installed but don’t use them unless I have to; on a Win 10 64bit box.
This is a stand-alone version of Sketchup, but maybe it needs web access for the layers – that’s counter intuitive for me but could be the case.
View SMP's profile
SMP
#5 posted 05-23-2019 06:38 PM
- SMP
I normally run Firefox, I have Chrome and IE installed but don t use them unless I have to; on a Win 10 64bit box.
This is a stand-alone version of Sketchup, but maybe it needs web access for the layers – that s counter intuitive for me but could be the case.
- Horus
Disregard, I thought you were running Sketchup Free, the web based.
View LeeRoyMan's profile
LeeRoyMan
101 posts in 116 days
#6 posted 05-23-2019 06:44 PM
View Rich's profile
Rich
4482 posts in 978 days
#7 posted 05-23-2019 07:01 PM
A cylinder is easy. Draw a circle with the circle tool and use Push/Pull to pull it up into a cylinder.
-- Knowledge is not skill. Knowledge plus ten thousand times is skill. -- Shinichi Suzuki
View EarlS's profile
EarlS
2792 posts in 2737 days
#8 posted 05-23-2019 07:05 PM
It’s been 3-4 months since I used SketchUp, but they had fairly decent on-line reference as well.
Use the circle tool to put a circle on the surface then use the push/pull tool to push it into the surface. It uses the same concept you use to make a 2D square into a 3D cube.
Horus
39 posts in 57 days
#9 posted 05-23-2019 07:16 PM
- LeeRoyMan
Thanks – I missed the side bar that pops up with this. Appreciate the help!
Horus
39 posts in 57 days
#10 posted 05-23-2019 07:17 PM
- Rich
Thanks – I hadn’t used the push/pull tool before, very useful.
View Tim Lanier's profile
Tim Lanier
2 posts in 124 days
#11 posted 05-30-2019 07:26 PM
It s been 3-4 months since I used SketchUp, but they had fairly decent on-line reference as well.
- EarlS
Yes – definitely check out the info on the website. https://learn.sketchup.com/
Even after using SketchUp for 10 years (with no attempt to learn the right way to do things) I learned several things in a very short time from the SketchUp Fundamentals track.
It’s worth the very small investment in time to learn the right way to use the tools. Now that I’ve been through some training I spend much less time getting things drawn up, and going back to a model and making changes no longer makes me pull my hair out.
