Adventures in Miter folding - CNC style
« back to CNC Woodworking forum
Forum topic by DS posted 05-22-2019 11:09 PM 4377 views 3 times favorited 67 replies Add to Favorites Watch
View DS's profile
DS
3858 posts in 3582 days
05-22-2019 11:09 PM
Topic tags/keywords: cnc miterfold trick milling modern
I’ve been wanting to do this for a long time. It took some doing and a LOT of Algebra.
This is a software construct, or “smart part” in Cabinetvision, where it adopts the overall size of my Assembly for Height, Width and Depth, allows a user entry for the skin thickness to leave behind and uses the precise material thickness to make the final fitment adjustments.
Then, it cuts out of a single piece of material with the press of the start button.
The joint was fairly invisible in MDF, so I traced it with pencil so you could see it.
Rockler has a tablesaw dado set that will make a similar joint, but, the setup uses shims and blade height adjustments to get the fitment right. (Not to mention it costs $389, AND it won’t work with our SawStop TS)
With my CNC programming construct, the setup is over. Just select the material and the overall sizes and output the g-code baby! No fuss, no muss.
After this worked I felt like a proud new Papa who just got a new baby boy!
(Funny, I know.)
I love it when a plan comes together.
-more pics added-
More adventures in miterfolding;
These are 108” long, sequence-matched, quarter-sawn Walnut panels.
They will enclose two fridge and freezer integrated columns that will also have matching sequenced Walnut front panels.
Joint side of the panel
Dry fit with packing tape on veneer face
Easy Peasy!
I’m currently adapting this software construct for floating shelves.
Can you tell I’m having fun?
67 replies so far
View DS's profile
DS
#1 posted 05-22-2019 11:26 PM
In case you are wondering of what use a joint like this might be;
(This is a random image from the interwebs – not my project)
I’ve done a kitchen very similar to this, (also in Macassar Ebony), that was featured on the cover of Phoenix Home and Garden a couple of years back. (It’s behind a paywall, so if you subscribe you can read all about it)
I sure wish I had this construct way back then.
View Desert_Woodworker's profile
Desert_Woodworker
7492 posts in 2376 days
#2 posted 05-23-2019 02:48 AM
Fantastic project! Yes I can only “imagine” the mental workout
-- Desert_Woodworker
View Joe Lyddon's profile
Joe Lyddon
10963 posts in 5214 days
#3 posted 05-23-2019 07:00 PM
DS,
Cool way to go!
What kind of Router bits were used to cut it?
I have been studying CNC for a few months now… Started by discovering Dave Gatton & his designed systems.
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: https://www.ncwoodworker.net/forums/index.php?media/albums/users/joe-lyddon.1389/
View DS's profile
DS
#4 posted 05-23-2019 08:52 PM
This miterfold joint utilized four seperate bits;
  • 1/2” Down Shear for the main dado bit
  • 1/4” Down Shear for the secondary dado bit (the construct will auto select between 1/4” or 1/2” depending on the needed dado widths)
  • 1/2” 45 degree bit for the miter
  • 1/2” compression cutter for the part outline cut
This could be done with a minimum of tooling, (1/4” DS and the 1/2” 45 degree miter bit), but we have a fully stocked 10-tool carousel, so the best tool for the job, I say. Plus the added benefit of cutting at 800 ipm with the 1/2” tools is way faster than the 300 to 400 ipm on the 1/4” tool.
This construct is about to get a good workout as we have two fairly large kitchen projects coming up right away. One is horizontal grain-matched Quarter Sawn White Oak and the other is Quarter Sawn Walnut.
Miter-folding grain-matched panels has always been a pain in the you-know-what. That is part of why they are so much more expensive. It will be interesting to see how much our productivity is increased with this new system.
Joe Lyddon
#5 posted 05-24-2019 08:31 PM
Very good!
Sounds like you have a SUPER CNC Router system at work!!
Your at home… will it also have a tool carousel? :)
Thank you!
View DS's profile
DS
#6 posted 05-28-2019 02:09 PM
I am at the point where I will have to finalize that decision soon. I’ve nearly decided to run a basic spindle and get producing then change to the ATC with a carousel later.
The cost difference is about $600 vs $3500.
Every time I have that kind of money socked away there always seems to be another place to spend it.
As for the machine I have at work, you can see it here;
https://www.lumberjocks.com/topics/235553
and yes, it is a beast of a super machine. (Not the newest, but it sure is a work horse.)
View DS's profile
DS
#7 posted 06-05-2019 02:35 PM
I figured out that the pic updates might work better at the top of the post, so I moved them.
View DS's profile
DS
#8 posted 06-08-2019 04:08 PM
Finished panels being installed.
Matching Doors and appliance panels will go on soon..
Desert_Woodworker
#9 posted 06-08-2019 04:21 PM
Sweet!
View DS's profile
DS
#10 posted 06-21-2019 04:38 AM
I’ve been buried in the horizontal-grain-matched-quarter-sawn-white-oak job all week. I had to manually nest the veneers in the kitchen a sheet at a time as there was a lot of tricky joinery and fancy panel pairings.
In the end it will look deceptively simple, but should look spectacular.
The cnc machine has been cutting Oak panels all day and the first results look very promising
The veneers in the kitchen took over five hours to nest today. What a headache.
It would’ve taken about 15 minutes to nest a similar vertical non-grain-matched job.
Sorry no pictures at the moment. Thought I’d drop this in on the way to the sack.
Now that we have this construct, though, it seems the jobs are lining up to use it.
Upcoming, is another contempo job with chemetal laminates. The options for banding end panels are limited, so the miterfold may be in play again. This job with have Ultra-gloss white lowers with satin-bronzed aluminum uppers.
It will also Include the first of what will become a new luxury closet line for us that is based on the “Open closet” concept rather than the more traditional reach-in closet format.
That is a whole new series of constructs whose framework is just starting to take shape.
Desert_Woodworker
#11 posted 06-23-2019 01:54 AM
Fantastic update on how far woodworking/cabinet making has come…
Please include pics on your next post for this cabinet making 2019
View Underdog's profile
Underdog
1688 posts in 3198 days
#12 posted 06-23-2019 12:45 PM
That is very cool.
I might have to try this myself.
-- Jim, Georgia, USA
Underdog
#13 posted 06-23-2019 12:45 PM
Sorry for the double post. The forum software/server is really acting up.
View DS's profile
DS
#14 posted 06-24-2019 11:24 PM
Island Post – ready to fold
Island Post Folded (Yes, it is also horizontal grain)
Fillers and Finished Ends – ready to fold
Fillers – folded
View DS's profile
DS
#15 posted 06-24-2019 11:27 PM
A glimpse into the open closet concept. (Image is from a hotel in Dubai – inspiration photo only – not my project)
The system is completely modular and the cabinets are on hidden shelf standards that can be moved around to suit the mood of the day.
showing 1 through 15 of 67 replies
