Hi,
I'm trying to convert an attached garage to a bedroom we live in NY. There is a heated basement underneath the concrete slab.
Few questions.
1. what type of flooring should I consider. engineered hardwood tongue and groove the floating style or laminate?
2. the garage floor is not even. I was considering using a leveling mix but then got an idea of using 2 by 4 and just level the floor and add plywood over and then the flooring.
3. do I need a moister protection? since the garage does not get flooded and there is basement underneath of the garage. But i would imagine the concrete slab does have different temperature than the rest of the house.
4. i was also considering using some type of insulation in the floors. What should do you recommend?
5. maybe there is another forum where I can ask my questions?
Thanks
You need to know how out of level your over all floor is. Focus on the the leveling first. A little don't worry, a lot you will need some leveling compound applied to slab. You will get creaking sounds if you do not get it leveled properly. After that an under layment in most cases will add padding and a vapor barrier in one. You don't say where you are. Climate will make your choice of insulation for you. Cold climate on concert slab means more insulation, warm simple underlayment will do. Hardwood is always the best, but laminate is cheaper.
Take a look at self leveling cement to level the floor. With heated living space below, you may not need a vapor barrier, but that's inexpensive and easy to install - just some plastic sheeting or more expensive you could use tyvek.
With heated space below, you shouldnt need to insulate the floor. However, you'll want to put some kind of subfloor in, unless your tiling the space - then I'd opt for in-floor heating (you can do that before the self-leveling cement to imbed it). Most garages aren't heated well, so you'll need to do something, kind of a two birds thing. If you heating the rest of the house with a boiler, you could tie into that system, if it's big enough. Otherwise electric would work, but be more expensive to run. If you plan to run forced air, again check capacity of existing furnace, the inspector will…
Oh, that's tight the question was about the floor… Take a look at the 2×2 ft subfloor panel, that are formed plastic down and plywood up, that may be adequate vapor barrier, check local codes. I like those panels, the floor isn't so hard and sounds and feels more like living pace instead of a garage ( or basement).
+1 Thanks, Horus! Saved me a lot of typing!! Thinking of doing same for my garage shop in (slow) progress.
bnisirov - I'm a good bit East of NYC, but But as a life-time NY'er, I'm assuming you're in the boroughs. Double check that 'slab'. Make sure it's structural (Rebar, Structural Steel, Steel Columns, etc.). 'Slabs' technically sit on the grade or ground, with a porous stone base.
'Sketchy' renovations are commonplace in those locales. Great, solid houses, but for good or for bad, many people worked on and added onto their homes themselves. Because they knew how. Well, not everybody!! Take a very close look before you start!
MSquared - there is a basement underneath of the garage. and what do you mean by structural if the garage is designed to hold up a car wouldn't it be structural enough for a person to sleep in?
Before you do anything, check with the county inspector. I know of some areas in the country that prohibit DIY construction. My brother-in-law was living in NJ and decided to put in a poured concrete walkway. The county inspector saw it during making his "rounds", asked to see his permit (didn't have one) and directed him to rip it all out. If he ignored that, the county would send a crew to rip it out and charge him for the removal. This was in a semi-rural area.
I was referring to the odd chance that someone dug out under the garage to add a room with home-spun reinforcement. Weirder things have happened. If it's part of the original construction, fine then. I wish I had a space like that!
If the floor is in fact a concrete floor that is reinforced to support autos in the garage, it clearly is strong enough for anything you'd use it for short of an anvil warehouse.
Since the floor is not sitting on the ground and the space is heated below, it's just a floor, though happens to be made of concrete. Now, it is possible moisture could come in from the edges of the concrete. I assume it contacts the ground somewhere. So there is some possibility of moisture getting in at the edge.
As has been said, might as well treat it like it is a slab on grade, and put moisture barriers as described for the type of flooring you are putting it.
I see no reason to build up the floor with 2×4 etc unless it is in fact not level. Some garages have a pronounced slope towards the garage door. You could easily have an inch or more drop it the floor. In that case you might want to use a true floor leveling compound which I imagine has some limit to how thick and can be spread. But even if generally level, it will NOT be flat. So you'll still need to fill in the low spots.
Some engineered wood flooring is meant to go right on top of a slab, with appropriate moisture barrier and usually a thin sheet of foam for sound dampening.
If you are putting down a traditional wood floor, then plywood can be put down first to give you something to nail the floorboards to.
As others have said, best get a permit for this.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
