How should I finish a picnic table made from white wood?
Forum topic by RecoveringDeveloper posted 05-21-2019 04:16 PM 1222 views 0 times favorited 22 replies Add to Favorites Watch
View RecoveringDeveloper's profile
RecoveringDeveloper
7 posts in 417 days
05-21-2019 04:16 PM
Topic tags/keywords: white wood weather proofing termites
Can you use wood filler on a project like this? Some of my joins have bigger gaps than I would like and I’m not sure how to fix them.
Second question, someone told me white wood isn’t good for a picnic table. I guess rain + termites. I still wanted to finish the project though. Any advice on how to seal it? I actually really like how it looks as it is without any finish. Pictures are attached.
22 replies so far
View LittleShaver's profile
LittleShaver
676 posts in 1395 days
#1 posted 05-21-2019 04:38 PM
If you want to go with a clear finish, be prepared to redo the finish every year. In which case, go ahead and use wood putty for your joints, you can re-apply it when you re-finish the table every year.
Not a very positive outlook, but clear finishes and the sun do not play nice together.
-- Sawdust Maker
View bilyo's profile
bilyo
1112 posts in 1878 days
#2 posted 05-21-2019 06:31 PM
I think it looks good. The fact that you don’t have any complex joinery is good as this wood will move a lot in an exterior environment. First, don’t use any filler in the miter joints. It won’t look good and it will likely fall out eventually. Leave the joints as they are and let the wood move. You don’t indicate how the miters are held together. If they are only glued, you can count on them falling apart. Some mechanical brackets underneath that will accommodate wood movement might be best for the long term. Because the sharp points on the miters will soon weather and splinter, you might consider replacing the end boards with full width pieces and plain butt joints. Then fasten with flat mending plates underneath.
Based on my experience with using white wood on the exterior; use a good quality exterior stain or, if you don’t want any color, use something like Thompson’s Water Seal and re-apply every year. You might want to seal the end grain particularly where it will contact the ground with something like this.
View Aj2's profile
Aj2
3087 posts in 2574 days
#3 posted 05-21-2019 06:47 PM
Your going to have to paint it. It will last longer if you primer then paint.
-- Aj
View pottz's profile
pottz
9902 posts in 1760 days
#4 posted 05-21-2019 06:57 PM
id stain or paint it with a good quality paint and as bilyo said dont bother trying to fill the gaps it wont hold anyway and make it look worse.
RecoveringDeveloper
7 posts in 417 days
#5 posted 05-22-2019 07:00 AM
Okay, thanks for the tips guys. I’ll skip the wood filler. Do I need to take it apart to apply the clear coat? If I do that will be a lot more work than I planned but if I don’t I’m worried about the wood that isn’t directly exposed getting damaged
As requested it’s held together with 3” exterior screws. The lumber (id 090214009289) is heat treated.
Here’s the latest progress pic.
View anthm27's profile
anthm27
1721 posts in 1886 days
#6 posted 05-22-2019 09:02 AM
It looks great, dont let a few gaps in the joins put you off.
You can buy a termite treatment in a one or two liter tin that can be applied to raw wood (brush on) pre stain , paint or oil. Termites dont like eating wood that has been coated in it.
Personally I would go for a good quality oil based decking oil.
Regards
Anthony (Hong Kong)
-- There is no hope for any of us if we keep apologizing for telling the truth.
View Lazyman's profile
Lazyman
5440 posts in 2163 days
#7 posted 05-22-2019 11:51 AM
+1 on no filler. I would probably just apply a semi transparent or opaque stain. If it sits in the sun, it will need to be refinished more often. If you can keep it off the ground by putting in on bricks or concrete for example, termites and rotting in general will be less of an issue. Or, you could replace the pieces in contact with the ground with pressure treated lumber to get a little longer life out of them and/or just replace them when they start looking a little rough.
View MikeDilday's profile
MikeDilday
285 posts in 1235 days
#8 posted 05-22-2019 11:53 AM
Check out Rustoleum Coppercoat. I am using it on a carriage door made of southern yellow pine and it looks promising. A pile and lumber company that I bought it from use it on docks that are submerged and they said it is good stuff.
-- Michael Dilday, Suffolk, Va.
View HackFabrication's profile
HackFabrication
168 posts in 488 days
#9 posted 05-22-2019 12:33 PM
I’m with the crowd, not to use any filler.
Structural grade lumber is going to move around quite a bit as it acclimates. Even tightly screwed down boards are going to cup and bow. Pretty much the nature of this structural wood, that for the most part is protected in the interior of a house (studs, etc.), where it’s not exposed to the elements.
My big concern would be where this table is going to rest. If it’s on grass, or bare ground, the four 2×4’s on the bottom are not going to last many years. Same for the raw ends of the table/bench legs. You’re looking at an annual or bi-annual refinishing operation to keep this looking somewhere near pristine. Sun, snow, rain all will take their toll on the white wood. Or any wood. Trust me, I did annual battle with a cedar deck, for almost 20 years. A chore I finally got rid of, when I re-decked with Trex.
From an economic standpoint, I’d find some reasonably priced deck sealer, and go with that. IMO: You’re wasting time/energy/money applying anything else.
-- "In the end, it's all Hack..."
View tomsteve's profile
tomsteve
1038 posts in 1995 days
#10 posted 05-22-2019 01:01 PM
sherwin williams A100 non tinted would be what i put on it. id thin some and let it soak into end grain then a couple coats unthinned.
the wood will start rotting at end grain so ya want to do what ya cant to seal that up but youre probably going to have to maintain it every other year or so.
6245 posts in 3269 days
#11 posted 05-22-2019 01:09 PM
The A100 mentioned above will work very well, and be a lot cheaper than many alternatives.
View theart's profile
theart
192 posts in 1330 days
#12 posted 05-22-2019 02:05 PM
My big concern would be where this table is going to rest. If it s on grass, or bare ground, the four 2×4 s on the bottom are not going to last many years.
- HackFabrication
Same here. If this was going on grass, I would get some patio pavers under it to keep the bottom a little dryer.
View Davevand's profile
Davevand
179 posts in 1612 days
#13 posted 05-22-2019 02:21 PM
you will want to seal any wood that contacts the ground. I made an adirondack chair out of white wood and used a thin epoxy on the bottom of the legs to seal them. Also prime and paint all sides before you assemble.
The chair lasted about 12 years before it rotted away, it rotted from the bottom up.
View SMP's profile
SMP
2126 posts in 681 days
#14 posted 05-22-2019 03:52 PM
- Davevand
Agree here, something on the bottom. Whether its the little metal/plastic “feet” or sacrificial seperate block, etc. Though I don’t think its completely necessary to prime and paint. A good UV exterior stain/oil finish will work well as long as you maintain/reapply every coupple years.
HackFabrication
#15 posted 05-22-2019 04:07 PM
I made an Adirondack chair out of white wood and used a thin epoxy on the bottom of the legs to seal them. Also prime and paint all sides before you assemble.
- Davevand
SMP
I believe there’s some sort of federal or state law that mandates Adirondack chairs be painted…..
And I agree, I don’t think paint is the answer. Penetrating stain, either color or clear. He’s going to be re-doing it numerous times before it rots to the point of being useless.
