Spray can of oil based polyurethane
Forum topic by Patrickgeddes14 posted 05-17-2019 08:58 PM 236 views 0 times favorited 4 replies Add to Favorites Watch
View Patrickgeddes14's profile
Patrickgeddes14
162 posts in 266 days
05-17-2019 08:58 PM
I have varathane in a spray can and also have it in a quart. There’s no cleanup if I use the can, are the results compromised compared to a regular sprayer?
View bilyo's profile
bilyo
777 posts in 1553 days
#1 posted 05-17-2019 09:23 PM
I sure look forward to seeing what the experts say about this. Coming from personal experience, I would guess the answer is no. Other than cost, I think the only difference, if there is one, might come from what I think is a thinner mix coming from the spray can. This would only mean more coats required for the same result.
View Rich's profile
Rich
4693 posts in 1040 days
#2 posted 05-17-2019 10:11 PM
What are you spraying? Aerosol is fine for smaller pieces, but trying to cover a larger flat surface with it won’t go well. It’ll be difficult to get it even. That’s pretty much true for any cone shaped spray pattern.
If you have a fan shaped head that fits on the aerosol you’ll have better luck. Maybe Varathane comes with a fan spray head. Some aerosols do these days. Even then, I wouldn’t try to tackle anything larger than a couple of square feet with a can.
-- My grandfather always said that when one door closes, another one opens. He was a wonderful man, but a lousy cabinet maker
View LeeRoyMan's profile
LeeRoyMan
211 posts in 178 days
#3 posted 05-17-2019 10:21 PM
Don’t know, I read something about solids once, but don’t know what they meant.
View JohnMcClure's profile
JohnMcClure
646 posts in 1091 days
#4 posted 05-17-2019 10:27 PM
Use the can up on one project and you’ll be fine. If it sits too long, the poly coagulates over the nozzle and it’s difficult to recover.
First coat goes on kinda “orange peel-ey” because of the individual particles coming from the spray can, if I recall. Second or third coat should solve that though, sanding lightly between coats.
Per sqft of coverage it’s too expensive, but convenience is a plus. No loss of quality if I recall.
-- I'd rather be a hammer than a nail
