Dust Right 4" hose equivalent?
Forum topic by jbswearingen posted 05-16-2019 11:57 AM 635 views 0 times favorited 5 replies Add to Favorites Watch
View jbswearingen's profile
jbswearingen
150 posts in 3403 days
05-16-2019 11:57 AM
I don’t need the flexibility of Rockler’s hose—it will temporarily connect my TS to DC until I get final shop layout done and ducting on the walls.
Any suggestions for less expensive hose that’s compatible with Dust Right hardware?
-- Semper fi, Brad
5 replies so far
View DutchW's profile
DutchW
3 posts in 889 days
#1 posted 05-16-2019 03:10 PM
Look to your home centers. Some offer 4” drain hose for exterior use, they come solid and with a drain field opening, no slots works better ;-)
jbswearingen
#2 posted 05-16-2019 03:12 PM
I still need a flexible hose to reach the machine but I don’t need it to be springy like the DR stuff.
-- Semper fi, Brad
View M. Chippa's profile
M. Chippa
35 posts in 995 days
#3 posted 05-16-2019 03:27 PM
Goto your store of choice and see if they have 4” flex duct. Im using 4” neoprene I picked up down the road. If you wanted something more cost effective you can go for aluminum.
View ArtMann's profile
ArtMann
1483 posts in 2059 days
#4 posted 05-16-2019 04:12 PM
Just about every major woodworking equipment on line store sells 4 inch flexible duct. Rockler is usually the most expensive. They are so expensive on most things that I can’t do business with them. Very often, Amazon will be your lowest cost, fastest delivery option. Here is one other example.
https://www.ptreeusa.com/
View bigJohninvegas's profile
bigJohninvegas
1096 posts in 2705 days
#5 posted 06-22-2019 05:22 PM
I use the harbor freight 4” hose with all my dust right fittings. works perfect. I have to order it, not an item my local store keeps on hand.
Bought two of them five years ago. Still working fine today.
And I like that its a clear hose. Easy to see if you get a clogged hose.
https://www.harborfreight.com/4-inch-x-10-ft-transparent-dust-collector-hose-96478.html
https://www.harborfreight.com/4-inch-dust-collector-straight-hose-connector-97499.html
-- John
