Jointer bar placement
Forum topic by Peace posted 05-15-2019 11:35 AM 221 views 0 times favorited 3 replies Add to Favorites Watch
View Peace's profile
Peace
15 posts in 943 days
05-15-2019 11:35 AM
Topic tags/keywords: jointer bar
Which side of the jointer bar should rest against the blade, the taller or shorter side?
3 replies so far
View Lazyman's profile
Lazyman
3339 posts in 1749 days
#1 posted 05-15-2019 11:55 AM
If you are talking about the lock bar, the wider side usually goes against the blade. The taper or scoop sort of acts like a chip breaker on a hand plane to help clear the chips away.
View Carlos510's profile (online now)
Carlos510
277 posts in 734 days
#2 posted 05-15-2019 12:48 PM
Ditto what Lazyman said. In addition there is a larger clamping surface against the blade, giving the blade more rigidity reducing the chance of working things loose.
-- "If time is money, then I need a loan" , http://www.hobbyworkshopprojects.blogspot.com/
Peace
#3 posted 05-16-2019 11:51 AM
Thanks to Lazyman and Carlos510. That’s what I thought. My problem is apparently something else.
