Finish Technique for Maple Bed
Forum topic by Kevin posted 05-13-2019 07:37 PM 759 views 0 times favorited 16 replies Add to Favorites Watch
View Kevin's profile
Kevin
514 posts in 4488 days
05-13-2019 07:37 PM
Topic tags/keywords: maple finish dye stain glaze shellac
Hello,
I am in the process of building a new bed out of solid (soft maple) and was wanting to get some ideas on the best way to finish. Here are a couple ideas, but would always enjoy opinions and techniques from fellow lumberjocks expertise!
I would like for the final tone to be close to this from the general finish website. 1st row / 4th is Amber.
https://generalfinishes.com/wood-finishes-retail/water-based-wood-stains-and-dye-stains/water-based-dye-stain
Looks like you will need to click on <colors> then <dye>
option #1
- dye the wood to get a tone
- use dewaxed shellac
- use glazing stain
- (seal with lacquer) ?
option #2
- danish oil
- (would you seal with lacquer/varnish) ?
option #3
- Open to other ideas :)
Thanks,
Kevin
-- Williamsburg, KY
16 replies so far
View JKN's profile
JKN
10 posts in 1979 days
#1 posted 05-13-2019 07:45 PM
Minwax Antique Oil Finish
2 coats, let it soak in then wipe off excess
Let sit for 2 days, then a coat of clear Briwax
Good luck
John
View SMP's profile
SMP
4953 posts in 1189 days
#2 posted 05-13-2019 08:48 PM
Option 4: use that general finishes stain you linked to, applying as per directions, topcoat with 3 coats of satin arm-r-seal.
Kevin
#3 posted 05-13-2019 08:59 PM
Thanks for the suggestions!
I saw on another site the antique oil finish was popular. I’ll go check out the arm-r-seal also as I have not used it before.
Thanks!
-- Williamsburg, KY
View Rich's profile
Rich
7560 posts in 1872 days
#4 posted 05-13-2019 09:58 PM
In option 1, what’s the purpose of the glaze? Are you going for an antique look? Also, if you do go with dye, use a blotch control first. Maple can be bad. Just 1 part white glue in 6 or 8 parts water. Brush it on liberally and wipe it even. Let dry and sand off the raised grain. Be sure to do test boards so you’ll know if you need a second application of the blotch control.
View OSU55's profile
OSU55
2894 posts in 3273 days
#5 posted 05-14-2019 12:00 PM
Option 3 – use oil based dye mixed into ars. Thin first 2 coats 1:1 apply like danish oil, then finish out the way you want with the toned ars. Regardless of what you do you are coloring maple and as Rich said will need blotch control. Here is a blog on blotch control. Glazing can be done between coats
Kevin
#6 posted 05-14-2019 12:34 PM
Rich, yeah it was for an antique look I was pondering on. The blotching is the most important thing I’m concentrating on really, I do not want blotching. In my last maple furniture I built I believe I minimized blotching pretty good.
OSU55, I’ve watched a few videos which seem to follow that method, but it was for curly maple instead of regular soft maple.
Thanks for the help everyone!
Kevin
-- Williamsburg, KY
Kevin
#7 posted 05-14-2019 03:01 PM
Interesting article on the glue/blotch control, never really heard about that. How much of each do you guys usually mix up when conditioning a work piece?
Kevin
-- Williamsburg, KY
View Rich's profile
Rich
#8 posted 05-14-2019 03:27 PM
- Kevin
I use mason jars for most of things like that and dyes, etc, and do a quart at a time so I have some around. You want to apply it liberally, and you might need two applications, so keep that in mind. Wet the surface, wait a few minutes and wipe with a damp cloth so it’s even, then let dry a couple of hours. Sand lightly with fine paper or non-woven pad to remove the raised grain.
Kevin
#9 posted 05-14-2019 03:42 PM
Nice. I’ll be testing this out soon.
Thanks.
Kevin
-- Williamsburg, KY
Kevin
#10 posted 05-14-2019 08:12 PM
So basically 1/2c of glue and 3.5c of distilled water for a 1:8 ratio in a quart mason jar correct, give or take a little?
- Kevin
I use mason jars for most of things like that and dyes, etc, and do a quart at a time so I have some around. You want to apply it liberally, and you might need two applications, so keep that in mind. Wet the surface, wait a few minutes and wipe with a damp cloth so it s even, then let dry a couple of hours. Sand lightly with fine paper or non-woven pad to remove the raised grain.
- Rich
-- Williamsburg, KY
View Rich's profile
Rich
#11 posted 05-14-2019 08:17 PM
- Kevin
Yep. It’s a little difficult to make a smooth mixture, and the glue will settle with time.
Kevin
#12 posted 05-14-2019 08:24 PM
Ty Rich!
- Kevin
Yep. It s a little difficult to make a smooth mixture, and the glue will settle with time.
- Rich
-- Williamsburg, KY
View Rich's profile
Rich
#13 posted 05-14-2019 08:31 PM
Ty Rich!
- Kevin
Glad to help. Thank OSU55 too. The stuff really does work.
Kevin
#14 posted 05-14-2019 08:36 PM
Yeah, I’ve been reading his article/blogs for the past hour or so and trying to learn something there :)
OSU55, forgive me, but I have been wondering what are “ars”?
Ty!
-- Williamsburg, KY
OSU55
#15 posted 05-14-2019 09:32 PM
ARS is Arm-r-seal by GF. Glue sizing works great for blotching but as Rich said it will settle out in just a few days. Just mix it up well and it can still be used. I tend to mix smaller batches for that reason. Waterbased finishes work well also and dont settle out but are a bit more expensive than glue. Also as Rich said sand the raised grain after the blotch control is dry – I use the next grit higher than the finish sand, only by hand with the grain and a light touch – getting too heavy can create the blotching again. I prefer paper vs nonwoven pad as it cuts better.
