Shopsmith ER-10 tail stock centers
« back to Woodturning forum
Forum topic by WoodenDreams posted 05-10-2019 10:35 PM 1578 views 0 times favorited 8 replies Add to Favorites Watch
View WoodenDreams's profile
WoodenDreams
1433 posts in 1161 days
05-10-2019 10:35 PM
Was looking at a 1952 Shopsmith ER-10 for sale. The tail stock center point was solid or not free spinning. Can you tell me if it’s suppose to turn. Seems to me if it doesn’t turn, the wood stock spinning would heat up and burn. Does the tail stock point require a bearing for free spinning. Or, is it only to be lubricated to prevent burning the wood.
8 replies so far
View ibewjon's profile
ibewjon
2654 posts in 4043 days
#1 posted 05-11-2019 12:05 AM
An old lathe from the 50’s or early 60’s that I had was also a dead, non revolving center. I greased it and it worked fine. I now have a machine with a live center.
MrUnix
8777 posts in 3449 days
#2 posted 05-11-2019 02:25 AM
Dead centers work just fine, and have for hundreds (thousands?) of years. Wax (wood lathe) or oil (metal lathe) the tip now and then and it will be fine.
View Hockey's profile
Hockey
182 posts in 1662 days
#3 posted 05-11-2019 04:05 AM
My 10ER has a female morse taper #2 in the stationary tailstock. I would think that the one you are considering has one also. I use a regular live center with a #2 morse taper on mine.
WoodenDreams
#4 posted 05-11-2019 08:17 AM
The guy has two ‘Shopsmith V’ that he’s not willing to sell. This Shopsmith ER-10 he said he bought several year ago and has not used it yet, and he was going to clean it up and paint it but never got around to it. He’s asking a firm $200… The 1/2 hp motor runs, the pulley clutch is froze (sitting on the table under the motor), The features it has but I would not use because I already have separate machines for are,- Jointer (cutting blades good but jointer table is cracked),-Drum Sander (rubber drum is dried up and cracking),- Drill Press (has a good chuck),- Table Saw (table and fence is good and has both blade throat plates, regular and dado), Mortising adapter is missing but has 1/4 and 3/8 mortise bits… I would only be using it for a extra lathe and use the mortising options…. I told the guy I’d pass for now and think it over.
WoodenDreams
#5 posted 05-11-2019 08:26 AM
I’m also waiting on another used lathe a freind of mine has, that I already said I’d buy. It’s setting in a garage about 250 miles from me, but he won’t be able to get it to me for another month or so.
WoodenDreams
#6 posted 05-11-2019 08:34 AM
Thanks for letting me know the dead center is ok to use with wax or oil.
View Samdog's profile
Samdog
8 posts in 3314 days
#7 posted 05-12-2019 02:58 AM
I have an ER. I use it only for a lathe. Live centers with a no.2 morse taper are available. Penn State and other companies have the centers and also have adapters to add accessories such as chucks and mandrels to fit the ER.
View Redoak49's profile
Redoak49
5396 posts in 3238 days
#8 posted 05-12-2019 02:34 PM
I had a Shopsmith ER and used a live center in the Morse taper. You can easily find the even on EBay.
