Board feet estimate (waste factor ?)
Forum topic by rnels21 posted 05-09-2019 12:52 PM 983 views 0 times favorited 10 replies Add to Favorites Watch
View rnels21's profile
rnels21
8 posts in 1116 days
05-09-2019 12:52 PM
Topic tags/keywords: question
Does anyone know the typical waste favor when estimating a project ? I’m thinking it’s 10% – 15%. Thanks
-- MSsurvivor
10 replies so far
View Robert's profile
Robert
4835 posts in 2815 days
#1 posted 05-09-2019 01:17 PM
It depends on the project and to some degree, the species of wood.
Simply adding up board feet and adding a factor, like 20% usually doesn’t work for me because I can’t translate that into anything unless without knowing the widths of boards. Or else you’ll end up with a lot of waste.
For example, lets say you need several panels 1” wide. If you are figuring based on 6” wide boards vs. 12” wide boards you will get a much different, maybe less desirable result.
Typically, I use CutList to generate the cutting diagrams. But you need to know what widths of the stock you’re dealing with first.
I usually let the boards talk to me (yes strangely I’ve heard them say “I will make a good bookmatch panel”) LOL and hope a defect or grain matching issue doesn’t wish I’d gotten 2 more boards :-)
View pottz's profile
pottz
22315 posts in 2319 days
#2 posted 05-09-2019 01:36 PM
well ive never really thought about it i always but a lot more than ill need and whats left just goes to another project.id say probably less than a few percent of wood goes into the trash so i dont spend a lot of time figuring it out.
View diverlloyd's profile
diverlloyd
4179 posts in 3192 days
#3 posted 05-09-2019 01:45 PM
50% if you waste less then you have extra for another project. If you waste that much then you won’t be disappointed as if you would be to using a lesser of a waste percentage. It also leaves a buffer for screw ups or for cut pieces that you don’t like.
View edapp's profile
edapp
347 posts in 2764 days
#4 posted 05-09-2019 02:18 PM
Got to be closer to 50% unless you are hand selecting boards of the right thickness and width/length for a specific project
I order random widths and lengths usually which means the waste is likely close to 50%, depending on the project needs. And by “waste” I dont mean trash i mean not used for that project.
View bondogaposis's profile
bondogaposis
6097 posts in 3686 days
#5 posted 05-09-2019 03:50 PM
I use 20% and that generally works for me.
-- Bondo Gaposis
View Rayne's profile
Rayne
1319 posts in 2874 days
#6 posted 05-09-2019 03:57 PM
I just ran into this issue recently myself. This is my opinion, but buying by Board Feet seems highly inefficient. Buying based on Sq Ft on a per board basis seems to be far more accurate from my experience. You just switch it over to board feet when calculating what you’re paying for. For example: If you’re ordering all 4/4 boards, calculate the Sq ft of what you’ll need for the project, add 10%, select your boards to meet the Sq Ft requirement based on your project, then switch to Board Feet to get an idea of what you’re cost is. Buying by Board Feet has resulted in multiple trips because the thickness of the board is a pre-determined figure that wasn’t as important as having the sq ft to cover the areas I want to cover properly. Just my logic and has worked the past 2 trips to buy lumber.
7356 posts in 3828 days
#7 posted 05-09-2019 03:59 PM
I’ve always went more-or-less by what Bondo suggested, the 20 %. But it is Kentucky windage, and can be a little off from teme to time.
View AlaskaGuy's profile (online now)
AlaskaGuy
6831 posts in 3644 days
#8 posted 05-09-2019 04:16 PM
It depends on the species, the grade, is it S4S or ruff cut.
I usually about figure 25%. I had some common ruff cut cherry that was about 50%. Best to get more that you need. I ran short on a project and when I went to get more I couln’t find a good grain and color match to the previous batch.
View CWWoodworking's profile
CWWoodworking
2311 posts in 1513 days
#9 posted 05-09-2019 04:53 PM
When figuring for cost, 50%
Actual? It will be all over the place depending on numerous factors.
When considering grades, don’t lock yourself into FAS or common. There is value in both.
View DrDirt's profile
DrDirt
4615 posts in 5077 days
#10 posted 05-14-2019 08:09 PM
Depends on the wood – - if it is to be cut from a Slab.. like the legs for the stand up desk to be steam bent…. 50%. If you are starting from relative straight, not “knotty” material like Kiln dried Oak or Poplar, or maple…. 15-20%
