Lathe Chuck for Shopsmith
« back to Woodturning forum
Forum topic by Redoak49 posted 05-08-2019 01:25 PM 397 views 0 times favorited 2 replies Add to Favorites Watch
View Redoak49's profile
Redoak49
5421 posts in 3278 days
05-08-2019 01:25 PM
I am looking at getting a lathe chuck for my Shopsmith 5. The Nova G3 seems to be very good and I can get the adapter.
What others should I consider and what size jaws?
I will be turning smaller things and likely less than 6”” or so like a small bowl or box with lid.
2 replies so far
View Phil32's profile
Phil32
1613 posts in 1193 days
#1 posted 05-08-2019 03:36 PM
You are on the right track. With the correct adapter to fit your spindle, the Nova G3 will work fine. You can also adapt most of your turnings to the standard jaws. Wait until your projects require different jaws before investing in other jaws.
-- You know, this site doesn't require woodworking skills, but you should know how to write.
View LesB's profile
LesB
3144 posts in 4732 days
#2 posted 05-08-2019 11:57 PM
The G3 is a good chuck. Do a little shopping around because prices vary. Also you will find that the chuck with the 3 sets of jaws in a kit will be a better overall deal in the long run and you will be set for almost any size turning. The chuck usually comes with the medium jaw set so you will need to add the small set for that you want.
Also the small jaw set comes in a short version and an extended type.
-- Les B, Oregon
