Proper glue to use
« back to Woodcarving forum
Forum topic by MrRon posted 05-05-2019 11:48 PM 280 views 0 times favorited 4 replies Add to Favorites Watch
View MrRon's profile
MrRon
5572 posts in 3665 days
05-05-2019 11:48 PM
Topic tags/keywords: question
I am building a large model and plan to use either balsa or bass wood. Due to its size, I want to glue up planks of the wood and then carve the wood to the desired contours. I don’t want the glue lines to show. I’m guessing regular strength Titebond would be right, or Elmer’s white glue. What do you say?
View ralbuck's profile
ralbuck
6062 posts in 2688 days
#1 posted 05-06-2019 12:02 AM
Years ago, I worked at as small lumber yard that had a good customer base for miles around, because of the owners knowledge and willing to treat the customers RIGHT! He only sold Titbond glue! No other branmds.
I have used it ever since and never been disappointed.
-- Wood rescue is good for the environment and me! just rjR
View bigblockyeti's profile
bigblockyeti
5782 posts in 2142 days
#2 posted 05-06-2019 12:15 AM
we had a bridge building contest in high school using 5/32” square balsa sticks to create truss bridges 3” wide spanning 12” and the objective was the maximum capacity with the minimum material usage, including glue. We ran out of Elmers with half the bridges built and the industrial arts teacher bought Tite-Bond for the remaining bridges to be finished (unfair advantage). Those glued with Tite-Bond had no joint failures with those, even with superior designs, did have joint failures and the strongest bridge failed at just over 160lbs. also glued with Tite-Bond.
View Aj2's profile
Aj2
2321 posts in 2220 days
#3 posted 05-06-2019 01:04 AM
I use Regular Elmer’s glue. It’s translucent invisible glue.
I also use a professional white glue from titebond thats translucent. If you want a glue with a short clamp time and fast grab the titebond translucent is good.
Regular Elmer’s has a longer open time.
Good Luck
-- Aj
View Belg1960's profile
Belg1960
1089 posts in 3487 days
#4 posted 05-06-2019 12:56 PM
Ron, is this a RR model? Like AJ suggested clear glue works well, but just keep in mind if your going to do weathering to the model if your using any thinners it will affect your glue.
Most RR modeler texture and weather before assembly. You get a much bigger range of contrast between the different boards. If you do it this way I use good old Elmers school glue and apply it with a toothpick sparingly.
-- ***Pat*** Rookie woodworker looking for an education!!!
