Boring hole in bowls and hollow vessels
« back to Woodturning forum
Forum topic by Jim Jakosh posted 05-05-2019 03:41 PM 712 views 0 times favorited 21 replies Add to Favorites Watch
View Jim Jakosh's profile
Jim Jakosh
22537 posts in 3469 days
05-05-2019 03:41 PM
Topic tags/keywords: tip lathe
When ever I make a bowl, I start the inside by drilling a hole down to where the bottom of the inside will be and that serves as a gauge spot for me. I usually use a 1/2” twist drill with a handle on it and I have a stop fixed on the drill to set the depth. Some people I have seen use Forstner bits to make that first bore.
Both of these heat up causing a lot of withdrawing to dump the chips out.
One day last year we had a guy demonstrating at our guild meeting and he used 2 spade bits so I thought I’d try them. I decided on 1 1/4” bits and LJ Doug Scott gave me a new one that I use for the first pass and I had another one that I modified for the final pass to the desired depth. Thanks Doug!!!!!!!!!!
Man do they work great. They hog out the wood with one drilling and the chips have lots of room to come out in the process. The second drill bit I ground to a radius on the leading edge and it follow the first hole and sets my depth. I do need to make a stop for it . I’ll probably add a 1/2” shank to both of these and slide the stops on that shank.
Here they are:
Some people probably already do this but I thought I share my experience because it worked so good!
Cheers, Jim
21 replies so far
View Jacksdad's profile
Jacksdad
233 posts in 788 days
#1 posted 05-05-2019 04:14 PM
The modified one works more like a scraper
View lew's profile
lew
12738 posts in 4119 days
#2 posted 05-05-2019 06:12 PM
Thanks, Jim!
I’m gonna “borrow” this idea!
View Wildwood's profile
Wildwood
2626 posts in 2499 days
#3 posted 05-05-2019 07:36 PM
great tip Jim, thanks for sharing!
-- Bill
View Mark Wilson's profile
Mark Wilson
2542 posts in 1427 days
#4 posted 05-06-2019 04:05 AM
See there? That’s what I’m talking about. You’re too clever, by half.
-- Mark
Jim Jakosh
#5 posted 05-06-2019 12:13 PM
Well this is not my idea. I saw it being used and thought it might be better than they way I do it and it is!. It will be my new method. Glad you guys find it useful too!!...like I say, Learn something new every day!!
Cheers, Jim
View Joe Lyddon's profile
Joe Lyddon
10587 posts in 4416 days
#6 posted 05-06-2019 09:08 PM
Another ”boring” way to start a project… :)
Cool way to make the “boring” more interesting and better with a nice rounded bottom of the hole…
View Nubsnstubs's profile
Nubsnstubs
1536 posts in 2094 days
#7 posted 05-06-2019 09:34 PM
I did that about 3 years ago. It certainly helps me get rid of that nipple I always have trouble getting rid of at the end.
Thanks for sharing…..... Jerry (in Tucson)
Jim Jakosh
#8 posted 05-07-2019 05:32 PM
Hi Jerry. I like to get to work quickly and slow boring is not on my agenda!
Cheers, Jim
Jim Jakosh
#9 posted 05-08-2019 02:45 AM
I roughed out 13 more apple bowls tonight for my neighbor and these drills worked super and hardly got warm at 1400 RPM.
Cheers, Jim
View Lazyman's profile
Lazyman
3339 posts in 1751 days
#10 posted 05-08-2019 05:06 AM
1400 RPM? Yikes!
Great idea. I’ll have to give this a try.
View robscastle's profile
robscastle
6029 posts in 2568 days
#11 posted 05-08-2019 09:20 AM
Hello Jim,
You may be aware anthm27 and myself have been attempting t refine the process for making Sungka boards., which is bowl making in minature.
We both have had issues with removing material for the cups or recesses, much the same as yourself, the twist drill suggestion is good as it serves as a depth gauge for the final depth. Agree fosrtner bits get way too hot and run the risk of damaging them as a result.
The spade bit is worthwhile following up on as it achieves the desired result without leaving a tit or dimple in the bottom. Then add the ease of modification and initial cost is definately a plus.
As others reported Jim good post!!
-- Regards Rob
View anthm27's profile
anthm27
834 posts in 1474 days
#12 posted 05-08-2019 10:03 PM
Nice idea Jim, Yes I did my first ever project with bowl cutter router bits the other day and quickly learnt that there was a lot of stopping and starting to remove the waste. I see that the hot waste sticks to the rim of the bowl and therefore the bits bearing is running on waste and not on the bowl itself, clearly not accurate until cleaned out.
As Rob mentioned above we have been looking for better ways. On a similar subject my bowl cutters are 1/2 diameter round, I would like a more round at the bottom of the bowl, is that possible?
Regards
Anthm
View ctsdeglpks's profile
ctsdeglpks
285 posts in 736 days
#13 posted 05-08-2019 10:29 PM
Yes Jim nice idea, thanks for passing it on.
Jim Jakosh
#14 posted 05-09-2019 02:37 AM
Thanks Anthony and Carlos!!
Hi Anthony. I was looking at a lot of sites but I could not find how they cut those perfectly radiused bowls in the game boards. I looked for 2 1/2 and 3 1/2 spade bits but could just find carbide inserts that were not round. I may make an attempt at making some with some tool steel. I have about 5 more projects to get done beore I look at it again, but I made a drawing of it.
Cheers, Jim
View mafe's profile
mafe
11979 posts in 3453 days
#15 posted 05-11-2019 10:49 PM
Fine idea Jim, thanks for sharing.
Best thoughts,
Mads
