Forum topic by CapeVerde | posted 05-01-2019 01:23 PM | 692 views | 0 times favorited | 3 replies | ![]() |
Topic tags/keywords: table burn damage heat refinish refinishing repair finishing varnish sander question Light colored kitchen table has a circular dark area approx 8” across caused by direct heat (pan). By the feel of it, some of the finish was burned off—not as glossy there anymore. I’ve done only a bit of woodworking/finishing, treat me as a beginner: Is this something that could be sanded and spot recoated with varnish, or repaired some other way, or am I looking at a complete refinish? It looks like the varnish is clear, or a light yellow. Not sure if that could be matched if just the spot were sanded out. Thanks for your help. |
3 replies so far
#1 posted 05-01-2019 02:30 PM |
You may be able to help the appearance a little, depending on what the finish is, but I have my doubts that you will be able to remove the spot. If it were my table, I would plan on refinishing the top if it really bothered me. |
#2 posted 05-02-2019 02:14 PM |
You say you are essentially a beginner. OK. I’ll put this out there just in case you would like to try it as a learning experience. You can always strip it and start from scratch if it doesn’t work out. |
#3 posted 05-02-2019 03:12 PM |
Long story short is, the only way you’ll get the table uniform is to refinish the entire top. Doing that can be a dog and pony show, frought with potential for problems if the veneer is thin, sanding through being the largest of the problems. So essentially you don’t have a lot to lose by trying a few things. Is it Ok to put something wet on this top? Or does the simple presence of water cause issues? Not a flood, just damp wet. If water is ok, damp a rag, and clean off the top where it is discolored. Then lay a towel, shop rag, whatever. White and clean are the criteria. Put the towel over the damp spot. Take an iron, with a steam setting. Place it over the towel, which is over the stain. Move the iron over the towel, and gently heat it. Take a look? Is it better? If not, place a bit more water on the top to re-moisten it, place the towel back over it, and re-apply the iron, this time giving it a few shots of steam as you move it around. Better now? If yes, quit, let it sit a few days. Still better, if yes good to go. If not quite right it can be re-done. If it is good to go, the finish is probably a Shellac, great finish in general, but not quite “sturdy” enough for a kitchen table. You may want to refinish the top with something harder like Poly, it would give it a lot more protection. But for placing HOT items on wood, it’s best to use a trivet type deal, something with feet so the HOT is away from the wood a bit. Using a hot pad, a lot of heat carries right through it, and a Shellacked finish will discolor either whitish, or darker like yours is. The other fixes for stains on most anything is rub either peanut butter, toothpaste, or Mayonnaise on them. I still have no clue what happens, but it often works, and if it were my table I’d go there first. None of them are likely to add any harm. -- Think safe, be safe |
Forum | Topics |
Woodworking Skill Share
13542 |
Woodturning
3007 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2075 |
Finishing
6709 |
8187 |
34176 |
CNC Woodworking
384 |
Hand Tools
6768 |
Jigs & Fixtures
1920 |
Wood & Lumber
7612 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5576 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9900 |
