Table Saw Sled
Forum topic by Innovator posted 04-28-2019 08:03 PM 608 views 0 times favorited 9 replies Add to Favorites Watch
View Innovator's profile
Innovator
3589 posts in 4180 days
04-28-2019 08:03 PM
Topic tags/keywords: plywood tablesaw sled grain orientation jig question
I am making my table saw sled top from a full 3/4” sanded ply. The top will be 36” wide and 30” deep.
My question is does the orientation of the plywood matter, in other words should the outer grain run parallel to blade or 90 degrees of it?
Thanks
-- Whether You Think You Can or You Think You Can't, YOU ARE RIGHT!!!
9 replies so far
View BlasterStumps's profile
BlasterStumps
1675 posts in 1206 days
#1 posted 04-28-2019 08:43 PM
If you have a piece of that ply that you could lay down on the table saw and slide back and forth, then turn 90º and slide again, seems that would answer your question. Personally can’t see it making enough difference which direction it is.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View ArtMann's profile
ArtMann
1480 posts in 1583 days
#2 posted 04-28-2019 08:50 PM
The plywood will work fine with either grain direction. However, I would encourage you to rethink the use of 3/4” plywood. It makes for a very heavy and hard to handle sled and you lose more cutting depth than is necessary. I have built several sleds for several different saws and found that 1/2” works better. I would also choose the lightest plywood with sufficient strength and quality to work. I used Birch. Yet another suggestion is to build more than one size sled to accommodate different size work pieces. I am planning on building an ultra light sled using 1/4” material for cross cutting small pieces.
Innovator
#3 posted 04-28-2019 08:54 PM
Thanks for the feedback, I have a smaller unit already, I am making this one for panels I am making for a project so the 3/4” seems to work best (Besides I got it free) I should be fine with the depth since the panels are only 3/4”
- ArtMann
View zzzzdoc's profile
zzzzdoc
567 posts in 3770 days
#4 posted 04-28-2019 10:16 PM
I have a large one built out of 3/4” MDF. It’s a back killer to lift it.
I actually put a hoist on the ceiling and lift it up and store it hanging from the hoist. It’s way too heavy and large to move around.
I’d think the 1/2” advice is very good. IMHO.
-- Before you criticize someone, you should walk a mile in their shoes. That way, when you criticize them, you're a mile away and you have their shoes.
View SMP's profile
SMP
2099 posts in 672 days
#5 posted 04-28-2019 11:55 PM
- ArtMann
I’ve also found that 1/2” birch seems to stay “flatter” than inexpensive “whitewood” 3/4 ply, at least in my shop.
View Lazyman's profile
Lazyman
5374 posts in 2154 days
#6 posted 04-29-2019 01:39 AM
Sand it to an extra fine grit and put a slippery finish (poly for example) on it and it won’t matter. At little paste wax will help too.
+1 on the 1/2” ply. I wouldn’t want to lose 1/4” of cutting depth.
Innovator
#7 posted 04-29-2019 10:25 AM
Thanks, I appreciate the info
Innovator
Sand it to an extra fine grit and put a slippery finish (poly for example) on it and it won t matter. At little paste wax will help too.
+1 on the 1/2” ply. I wouldn t want to lose 1/4” of cutting depth.
- Lazyman
Innovator
#8 posted 04-29-2019 10:26 AM
I have a large one built out of 3/4” MDF. It s a back killer to lift it.
I actually put a hoist on the ceiling and lift it up and store it hanging from the hoist. It s way too heavy and large to move around.
I d think the 1/2” advice is very good. IMHO.
- zzzzdoc
Innovator
#9 posted 04-29-2019 10:28 AM
Thanks ArtMann
- ArtMann
