Wood Gears
Forum topic by AustinEl posted 04-27-2019 11:58 PM 589 views 2 times favorited 6 replies Add to Favorites Watch
View AustinEl's profile
AustinEl
1 post in 746 days
04-27-2019 11:58 PM
Topic tags/keywords: gear gears bevel search question
Hey all. I am really interested in making wood gears, and have found some great projects on this site. I was trying to find more information on how to make them (specifically bevel gears) but for some reason search on the site is not working. I’ve tried searching for “gears”, “bevel”, and even things I know will return results (such as “sled”) and nothing is returning.
I was wondering if I’m doing something wrong, or if someone could point me in the direction of a forum, blog, etc that this topic would be located in.
Thanks in advance.
Austin
View OhioMike's profile
OhioMike
89 posts in 3244 days
#1 posted 04-28-2019 12:30 AM
Have you seen Matthias Wandel’s YouTube channel?
https://www.youtube.com/watch?v=t-yvaZrtxFE
View unclearthur's profile
unclearthur
383 posts in 2870 days
#2 posted 04-28-2019 12:44 AM
Or his website, aptly named https://woodgears.ca/ where he even has a gear template generator.
View Delete's profile
Delete
439 posts in 1454 days
#3 posted 04-28-2019 02:25 AM
You read my mind I just posted an article from an old 1961 PS. Also included is a download link to a nice wooden gear clock plan and a link to Matthias’s making gears page. Here’s the link.
https://hobbyworkshopprojects.blogspot.com/2019/04/make-wooden-gears.html
View CaptainKlutz's profile
CaptainKlutz
4446 posts in 2576 days
#4 posted 04-28-2019 05:37 AM
When I search, I find some threads using ‘wood gear’?
If you results are blank,
Suggest you might have issue with browser settings related to 3rd party cookies or ad blocking.
This search issue has come up recently in another thread, and might help you track down the problem.
https://www.lumberjocks.com/topics/304222
Cheers!
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
View Lazyman's profile
Lazyman
6991 posts in 2469 days
#5 posted 04-28-2019 12:56 PM
I experimented a while back making some wood bevel gears and posted a small blog about it here. I used the woodgears.ca free online tool mentioned above to print templates and basically use his method for cutting them but at a 45 degree angle. I have not made anything with them so I don’t know how well they will actually work in an application, especially with any sort of significant load, but they seem to work pretty well just playing around with them (I posted a video if you want to see).
Another novel way to make gears on the table saw or router table can be found at Steve Garrisons website. He sells an inexpensive ebook but has some videos you can see that demonstrates his process.
View lew's profile
lew
13355 posts in 4837 days
#6 posted 04-28-2019 03:43 PM
If you use Sketchup, here’s a plugin that might help-
http://sketchucation.com/forums/viewtopic.php?p=414082%23p414082
