Pipe Clamp Storage with Nine Inch Nails
Forum topic by poopiekat posted 04-27-2019 08:42 PM 1127 views 0 times favorited 11 replies Add to Favorites Watch
View poopiekat's profile
poopiekat
4521 posts in 4218 days
04-27-2019 08:42 PM
Okay somewhere I saw this method of storing pipe clamps and thought it was goofy until our furnace guy accidentally knocked over 10 of my clamps, 5 and 6 footers, off the wall standards and brackets. They all fell onto the electronic control module of our water heater.
Aside from the accident, I disliked storing the pipe clamps horizontally on those brackets. I saw this method somewhere and decided to try it. I used 2 layers of 3/4” birch veneer plywood to bridge the studs, and bored some holes for a snug fit for some masonry spiral nails, 8 inches long with polyurethane glue.
I bought 3/4” NPT iron caps, and drilled a 1/4” hole in them to which I screwed in some eye bolts.
Now I can select the clamps I need easily, and the whole works fits closer to the wall. My original idea was to simply drill 5/16” holes directly into the pipes and slide them onto the nails, but I wasn’t happy with how that turned out. So I got the end caps, and it makes retrieval and return of the clamps a lot easier.
Plus I got a good resistance workout with my manual pipe die set, it’s a hundred years old but still does a first class job of threading those old pipes. I salvaged them years ago as original 10 footers which I cut in half.
11 replies so far
View Delete's profile
Delete
439 posts in 856 days
#1 posted 04-27-2019 09:01 PM
Yes that works nice, mine are currently all stored in a pile on a couple of brackets in the metal shop, this looks much better. If you would have drilled the tail ends 1/2” instead of 5/16”, I think you would have been happier with them.
View diverlloyd's profile
diverlloyd
3601 posts in 2341 days
#2 posted 04-28-2019 01:09 AM
Poopie, storing them like that you can also use them as a clamp wall like some woodworkers are doing now a days.
View hairy's profile
hairy
2909 posts in 4016 days
#3 posted 04-28-2019 11:56 AM
It’s got a good beat, and you can dance to it.
-- Genghis Khan and his brother Don, couldn't keep on keeping on...
poopiekat
#4 posted 04-28-2019 12:05 PM
It s got a good beat, and you can dance to it.
- hairy
Hairy, you are way ahead of the curve with your meatless hamburgers.
Thanks for all the kind comments! I knew I wanted vertical storage, but I could not wrap my head around those designs using PVC pipes at the bottom to stow the clamps in, like a repurposed umbrella stand.
View TungOil's profile
TungOil
1319 posts in 979 days
#5 posted 04-29-2019 12:58 AM
And I came here expecting to see how Trent Reznor stores his pipe clamps.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View BuffaloBrewer's profile
BuffaloBrewer
73 posts in 1303 days
#6 posted 04-29-2019 01:50 AM
I believe he designed a downward spiral so he could get the clamps closer.
- TungOil
poopiekat
#7 posted 04-29-2019 12:44 PM
Those last two comments really...’Hurt’
View Sylvain's profile
Sylvain
872 posts in 2983 days
#8 posted 04-29-2019 01:08 PM
Excellent
I have a few aluminium sash clamps reinforced with a wooden batten as recommended by Paul Sellers.
I will screw screw-eyes in the end.
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
View LeeRoyMan's profile
LeeRoyMan
253 posts in 211 days
#9 posted 04-29-2019 04:08 PM
My umbrella stand is 30×60 on 8” wheels and will hold 105 bar clamps. So nice to wheel it over to where I am working instead of walking back and forth for each one.
But I do like the idea for people that don’t have the space.
View SMP's profile
SMP
1340 posts in 390 days
#10 posted 04-29-2019 09:49 PM
In my day, 9 inch nails were NINE inches long <shakes>
So the premise here is that the pipes have a head like a hole, and the black iron are black as your soul?
TungOil
#11 posted 04-30-2019 12:39 AM
- SMP
Yeah, he gets it….
