SuperMax 19-38 stand fix
Forum topic by hairy posted 04-20-2019 05:11 PM 389 views 1 time favorited 6 replies Add to Favorites Watch
View hairy's profile
hairy
3055 posts in 4271 days
04-20-2019 05:11 PM
When I bought the sander I also bought the factory stand. After not much use, 1 of the corners buckled, making the tool low in that corner. The temporary fix was to roll that wheel up onto a 3/4” thick scrap of hardwood. That temporary fix lasted a few years more than intended.
It could have been caused by the uneven basement floor, maybe I once put too much downward pressure on it when moving. I did not buy the factory casters, I had a set of Rockler’s on hand.
I finally got a roundtoit. I’ve needed one for a long time. I removed the tool from the base,straightened the frame and installed a 20” x 36 and 3/8” x 3/4” thick sheet of plywood. It is only held on by the caster bolts.
Before
After
It probably would have worked if I had bolted it to the bottom of the base. I did it the hard way. I loosened all the bolts, removed the half of the bolts holding the shelf, and installed it on the inside of the frame.
It’s nice to have a place for the sled I made for it.
-- Genghis Khan and his brother Don, couldn't keep on keeping on...
6188 posts in 3232 days
#1 posted 04-20-2019 05:59 PM
Thanks for that, I may add that to mine.
View WoodenDreams's profile
WoodenDreams
1038 posts in 649 days
#2 posted 04-20-2019 08:37 PM
Looks like a sturdy fix with the plywood added to the base. also give you a storage shelf.
View splintergroup's profile
splintergroup
3677 posts in 1961 days
#3 posted 04-21-2019 02:13 PM
That is how I added casters to my 16/32 base. The added height is great and I love how you took the extra time to fit the plywood above the base instead of the lazy bell-the-base approach I took 8^)
118047 posts in 4316 days
#4 posted 04-21-2019 02:46 PM
Had the same problem, thats a good fix, thanks for the tip Hairy
View Davevand's profile
Davevand
177 posts in 1575 days
#5 posted 04-21-2019 03:53 PM
I went one step farther, I replaced all my open stands for plywood boxes with drawers and casters. Opened up a lot of storage space so I can keep all the paraphernalia with each machine
View therealSteveN's profile
therealSteveN
5594 posts in 1313 days
#6 posted 04-21-2019 04:12 PM
Huh, when I got mine the stand was included, with the casters. I believe they may have reworked that portion of the unit, mine appears strong like Ox.
Your fix is good though, it’s extra storage and if you’ve made a sled for the sander it is a primo spot to store it.
Nice fix.
-- Think safe, be safe
