FS/ Air Compressor
Forum topic by rustynails posted 04-19-2019 01:11 PM 634 views 0 times favorited 11 replies Add to Favorites Watch
View rustynails's profile
rustynails
889 posts in 3266 days
04-19-2019 01:11 PM
I have a 5HP 60 gallon single phase 15 amp air compressor along with two hundred dollars’ worth of 75 ft. of industrial grade flexible hose, with wall mounts with 4 quick connect drops with one valve drop for clean out. The unit comes with a water separator and shut off valve and a extra long cord (about 35 ft) . This was used in my hobby shop and not commercially.
Asking $525.00 for everything.
Listed here on craigslist to view pictures https://images.craigslist.org/00h0h_el3nuSTHUTb_300x300.jpg
11 replies so far
View ChefHDAN's profile
ChefHDAN
1603 posts in 3587 days
#1 posted 04-19-2019 05:04 PM
Rusty, your link just goes to the picture not the posting, whereabouts are you located?
View AlaskaGuy's profile
AlaskaGuy
5730 posts in 3046 days
#2 posted 04-19-2019 05:13 PM
His profile say Mid Michigan
rustynails
#3 posted 04-19-2019 06:10 PM
rustynails
#4 posted 04-20-2019 09:12 PM
If anyone is interested in this I my be able to deliver Saturday 4-27-19 as I will be traveling from Saginaw, Mi.
to Indianapolis IN. and or back again on 5-5-19……
rustynails
#5 posted 05-14-2019 03:14 PM
First $450.00 takes it home with the extra air lines …
rustynails
#6 posted 05-20-2019 10:36 AM
This has been sold … Thanks for looking
View ArtMann's profile
ArtMann
1480 posts in 1553 days
#7 posted 05-20-2019 03:24 PM
It is not possible to continuously run a 5 horsepower motor on 15 amps. That is simple physics. Nice compressor though.
View TheGreatJon's profile
TheGreatJon
348 posts in 1971 days
#8 posted 05-20-2019 03:44 PM
Many compressors are advertised at “developed HP”, which is calculated without load. My “3HP” compressor runs on a 115v, 20A circuit, which is obviously not possible if it were actually putting out 5HP.
On 220v, 15A, you would be getting just about 4HP.
-- This is not the signature line you are looking for.
View Delete's profile
Delete
439 posts in 1109 days
#9 posted 05-20-2019 03:49 PM
Different brands often size there motors differently. Often companies supplying the consumer market with imports, size their motors close to 100 percent efficient based on the imput current and 746 watts per HP. Actual output power at the shaft is quiet a bit different. Older motors could be as low as 65 percent efficient, newer motors can top 80 percent efficient. This motor at 15A and 230/240V is closer to 3 HP than 5 HP at the output shaft. It’s all in the way they size their motors to promote sales.
ArtMann
#10 posted 05-21-2019 12:37 AM
I don’t think a company like Campbell Hausfeld would play specification games like Sears/Craftsman used to.
Delete
#11 posted 05-21-2019 02:09 AM
Below is a picture of my metal shop compressor it is 3 HP, I have two more, a 3/4 HP in my outdoor equipment shed and a 1.5 HP in the woodwork shop.I guess you can say I am the manufacturer, I built all three from components I collected over the years when the prices were right. The 3 HP is a beast, it’s a 2 cylinder single stage with aftercooler and I don’t have a tool that will run it down.
As you can see in the picture above, at right, it is plugged into a 15A 230V circuit. It has never tripped the breaker and I have even started it with the air unloader isolated. Below is the motor label.
The motor is an A.O. Smith motor, made in the USA in Tipp City, Ohio. Take a look at the specs. it is basically the same motor as above, 15A at 230V. Notice the one difference, the HP is actually an accurate statement of the power available at the shaft, 3 HP not 5 HP.
Campbell- Hausfeld has been around a long time and they do make an industrial line of equipment, but for the consumer market they are no different than anyone else and have turned to imports to reduce there costs and increase there profits.
