my replacement sharpening wheel
« back to Hand Tools forum
Forum topic by BlasterStumps posted 04-19-2019 03:20 AM 554 views 1 time favorited 8 replies Add to Favorites Watch
View BlasterStumps's profile
BlasterStumps
1689 posts in 1217 days
04-19-2019 03:20 AM
I put together a different sharpening wheel. My old one was too large and too heavy to move around. It also had a 1/2 hp motor. I found a $5, 1725 rpm, 1/4 hp Dayton motor so I figured now was the time to build a new wheel. I used a sanding disc from an old Craftsman belt/disc sander. The thing is nothing special, just a box with the motor mounted vertical so the disc is level with the top. I have found in using the old one I made some time ago that I mostly only used one disc with 120grit paper on it and a leather strop wheel. So I have a self-adhesive disc on the wheel and I drilled and tapped the motor shaft so I can set the strop wheel on top of it when needed.
I tried it out on a 2” socket chisel that someone had cut a few nails with. The chisel was made from some good steel so it took a few minutes to grind a new edge. Overall, I am liking the new wheel a lot.
Once I get a chisel ready for final shapening like I did the 2”, I then go to the diamond stone, wet stone and strop.
Anyway, here is what I put together. Sorry about the bright orange. I didn’t do it : )
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
8 replies so far
View wallkicker's profile
wallkicker
121 posts in 3932 days
#1 posted 04-19-2019 11:42 AM
Good idea !
View Jamie_Sharp's profile
Jamie_Sharp
2 posts in 449 days
#2 posted 04-21-2019 05:30 AM
Very cool how is it with only a 1/4 horse electric motor, is it enough torque? Good choice with the 1800rpm.
View Delete's profile
Delete
439 posts in 1150 days
#3 posted 04-21-2019 11:11 AM
This is not a new idea, the first one I have seen was way back in a 1941 PM magazine, D. Gingery improved a bit on the concept in 1981. Here’s the link to these plans,
https://hobbyworkshopprojects.blogspot.com/2018/12/old-becomes-new-again.html
Yours is also a nice example of this idea. If you follow D. Gingery’s idea and bring the table further out around the disk it will give you better support and control for hand work and it will be easier to mount jigs on the table that will allow you to perform precisely controlled sharpening.
BlasterStumps
#4 posted 04-21-2019 12:46 PM
- Jamie_Sharp
the 1/4 hp motor seems plenty. with 120 grit paper on the disc, it only takes a light touch. grind for a couple seconds, let cool, grind again, cool again. I just dip the tool in water each time.
BlasterStumps
#5 posted 04-21-2019 12:50 PM
My old unit did have the table out farther but I really didn’t make use of it. I sharpen basically free hand, no jigs. I only will brace against the top when I sharpen twist drill bits. The disc needs to turn cc for drill sharpening.
This is not a new idea, the first one I have seen was way back in a 1941 PM magazine, D. Gingery improved a bit on the concept in 1981. Here s the link to these plans,
Yours is also a nice example of this idea. If you follow D. Gingery s idea and bring the table further out around the disk it will give you better support and control for hand work and it will be easier to mount jigs on the table that will allow you to perform precisely controlled sharpening.
- Carlos510
View Redoak49's profile
Redoak49
4754 posts in 2766 days
#6 posted 04-21-2019 12:52 PM
Great build and use of a motor.
Delete
#7 posted 04-21-2019 01:01 PM
Thats great Blaster, adding a reverse switch would be convenient. Many small motor types are reversible.
Cheers
BlasterStumps
#8 posted 04-21-2019 01:03 PM
Thanks Redoak.
- Redoak49
