Can you lacquer over 6 month old lacquer?
Forum topic by scottcewing posted 04-12-2019 12:02 PM 447 views 0 times favorited 5 replies Add to Favorites Watch
View scottcewing's profile
scottcewing
9 posts in 812 days
04-12-2019 12:02 PM
I have a chess board I made with a high gloss rubbed out lacquer finish, using several layers of lacquer. What I didn’t see at the time were a couple small spots where I sanded thru to the wood. I noticed them when I was done but decided I’d go back and fix them later, and put it aside. Now it’s been six months, and I’m wondering if I can just go back and put some layers of lacquer over those spots (i.e. does lacquer still bond with lacquer if it’s been thoroughly cured?) and rub those out, or do I need to sand the whole thing off and start over?
5 replies so far
View OSU55's profile
OSU55
2651 posts in 2793 days
#1 posted 04-12-2019 12:31 PM
Doesnt matter how long its been, lacquer will still burn in to itself. Yes you are safe to do touch ups.
scottcewing
9 posts in 812 days
#2 posted 04-12-2019 01:15 PM
Awesome! Thanks!
View CaptainKlutz's profile
CaptainKlutz
3339 posts in 2298 days
#3 posted 04-12-2019 01:19 PM
- OSU55
+1 Just be sure to clean any old wax from surface.
View Rich's profile
Rich
5688 posts in 1393 days
#4 posted 04-12-2019 02:16 PM
If you used NC lacquer, then you can spray over it, although I’d wipe it with naphtha first and hit it lightly with some 320 or 400 grit sandpaper, just to make sure you have a clean, smooth surface.
However, if it’s catalyzed lacquer, then the sanding is mandatory since it will not amalgamate after a period of time.
View CWWoodworking's profile
CWWoodworking
871 posts in 982 days
#5 posted 04-12-2019 07:07 PM
Doesn’t this depend on the product? Most have a mil limit. I know mine does. How many coats?
