04-12-2019 11:28 AM
So I went into a local tool shop to peak around at what he had because I have never been there. The employee and I had been talking and she asked me if I was in the market for any particular tools at this time and I stated I was looking for a planer and a joiner, given the fact the store was loaded to gills with high end product I figured I was out of luck. After a few minutes of dialog she tells me she has a used JET joiner and we made our way over to it, at first sight I thought buy it. I needed to clam myself because its kinda what Ive been lookin for, I was very close to buying a table top model but really wanted cast Iron but i just cant justify it because of the amount of work i would do with it is minimal. I asked her how much and she told me 375 firm with the mobil base. I shouted SOLD!!!!!!! So from there I ran the model number JJ-6-CSX and saw the current models going for 1300 give or tke and felt pretty good about my purchase, the tables were in excellent condition the fence was solid and of course the blades were dull. So when i got it home I noticed online many of the used models were selling for about 375 so I still did ok. My frustration is coming from the blade set up but iam sure you all knew that already…..The instruction state that the blade should be 3/16 above the cutter head, but when I do and I set the outfeed table…( yes I already know I never touch the outfeed table once its set but I am working on my initial set up ) the blades hit the outfeed…Then I went and bought the magnetic set up jig set tables in parallel and then it looks and performs like I do not have enough blade sitting above the cutter head. Right now I have a 375.00 cast iron thing sitting in garage and no ambition to mess with it anymore…
8 replies so far
#1 posted 04-12-2019 11:46 AM
The manual I looked at said the knives should be 1/16” above the cutterhead. My 8” Jet says “approximately .079”...which is slightly more than 1/16”. I’d reset the knives lower and not fret about it too much. The other thing is that the outfeed table may not be co-planer. If the far end is up too much it might create the problem you have. I’m not sure that you mean when you say “performs like I do not have enough blade sitting above the cutter head”. Maybe you can elaborate a little?
#2 posted 04-12-2019 11:54 AM
Forget trying to get the knives 3/16 from anything. Does the cutterhead have jack screws on this model? If so run them all the way in, pick a spot to set your out feed table, make the infeed table the same height (probably about where a zero Pointer lines up) and bring the knives up to the out feed table height.
Here's a video
#3 posted 04-12-2019 12:02 PM
I have that same jointer. I set the knives differently. I install them all the way into the cutterhead, then adjust the tables to eliminate snipe. I keep the cutterhead from rotating and hold the knife down with a scrap of wood, then tighten the screws.
They all need to be at the same height. By installing them the way I do, they will be.
Jigs, micrometers, magnets or whatever method used are ways to install them all at the same height. Then you still need to adjust the tables to eliminate snipe.
-- Genghis Khan and his brother Don, couldn't keep on keeping on...
#4 posted 04-12-2019 12:18 PM
The manual I looked at said the knives should be 1/16” above the cutterhead. My 8” Jet says “approximately .079”...which is slightly more than 1/16”. I d reset the knives lower and not fret about it too much. The other thing is that the outfeed table may not be co-planer. If the far end is up too much it might create the problem you have. I m not sure that you mean when you say “performs like I do not have enough blade sitting above the cutter head”. Maybe you can elaborate a little?
- Fred Hargis
Fred is correct I meant to say 1/16th, Fred the blade is barely above the retainer bar,it seems like the bar and the blade are hitting the material. As far as jack screws, I have two small allen screws that the bar sits on and then the retainer bar. I am using a digital height gauge off the table so I know Iam pretty much dead on whatever number I use…
#5 posted 04-12-2019 12:38 PM
Sorry to read. Machinery can be very frustrating.
Did you start with only aligning the out feed table and cutter head to same plane? Then, Work on in-feed table coplanarity after they are set? You can adjust the table positions to be above the knives and create this problem if you work out of order.
Due geometry of the out feed table and cutter head; there can only be one of two problems: 1) The out feed table is too low. - Did you check that the gib screws are snug ( and out feed table is not moving up/down)? If these are too loose, there can be too much up/down movement in table. If too tight, can not adjust out feed table position. It’s a balancing act to get them set right. - Have you checked that the gib(s) for out feed table are not missing or damaged? If the gib is missing, or badly worn, it could cause the out feed table to be lower. - Cast iron is damaged.
2) The cutter head is too low. Considering the cutter head bearing blocks rest in a pocket in main casting, hard to see how this could happen unless the cutter head bearing caps are damaged? Regardless, since the bearing caps are held into casting from bottom with one bolt each side, you could insert some wide shim stock under each bearing cap and raise the head slightly. If adjusting the out feed table doesn’t work, and only need small lift; might try this. Be warned, to remove the cuter head bolts, have to remove/lift the entire cast iron assembly off the base.
PS – Once tool is out of warranty, Jet technical service/parts department does not really care if you bought machine new or use. They just want your machine working. If the checking/adjusting the gib(s) doesn’t fix the out feed height issue, give them a call. They helped me once over the phone fix a damaged CL purchased jointer.
Best Luck.
#6 posted 04-12-2019 01:56 PM
The manual I looked at said the knives should be 1/16” above the cutterhead. My 8” Jet says “approximately .079”...which is slightly more than 1/16”. I d reset the knives lower and not fret about it too much. The other thing is that the outfeed table may not be co-planer. If the far end is up too much it might create the problem you have. I m not sure that you mean when you say “performs like I do not have enough blade sitting above the cutter head”. Maybe you can elaborate a little.
- Fred Hargis
- slolearner
If you post a pic of the knives and gibs as they sit in the jointer we can at least check that you have the correct parts.
-- Aj
#7 posted 04-12-2019 02:49 PM
Due geometry of the out feed table and cutter head; there can only be one of two problems: 1) The out feed table is too low. - Did you check that the gib screws are snug ( and out feed table is not moving up/down)? If these are too loose, there can be too much up/down movement in table. If too tight, can not adjust out feed table position. It s a balancing act to get them set right. - Have you checked that the gib(s) for out feed table are not missing or damaged? If the gib is missing, or badly worn, it could cause the out feed table to be lower. - Cast iron is damaged.
2) The cutter head is too low. Considering the cutter head bearing blocks rest in a pocket in main casting, hard to see how this could happen unless the cutter head bearing caps are damaged? Regardless, since the bearing caps are held into casting from bottom with one bolt each side, you could insert some wide shim stock under each bearing cap and raise the head slightly. If adjusting the out feed table doesn t work, and only need small lift; might try this. Be warned, to remove the cuter head bolts, have to remove/lift the entire cast iron assembly off the base.
PS – Once tool is out of warranty, Jet technical service/parts department does not really care if you bought machine new or use. They just want your machine working. If the checking/adjusting the gib(s) doesn t fix the out feed height issue, give them a call. They helped me once over the phone fix a damaged CL purchased jointer.
Best Luck.
- CaptainKlutz
SUCCESS…!!! I USED THIS METHOD…I think I was so wrapped up in trying to use what I found and read on internet that I didnt stop to understand the mechanics of it and why snipe happens. Right now I have the cutterhead damn near flush with the apex of the blade and checked all 3. Never will I ever again coplane the in/out feed table then bring the blades in. From now on outfeed and blades then infeed to that, the biggest thing is the cutter head flush with the outfeed though….
#8 posted 04-12-2019 03:25 PM
Glad you figured it out. FWIW – the Jet manual is available online and it shows same alignment sequence. http://content.jettools.com/manuals/man_708457K.PDF
Remember, can believe less than half of what you read on internet. Biggest challenge is always figuring out which half. :-)
Cheers!
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
12697 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2572 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
516 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
377 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1663 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
5778 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
7383 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
30738 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
268 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
5986 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1624 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
6839 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1516 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2415 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1230 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
5146 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2323 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
9353 |
