Keeping glue joints aligned
Forum topic by MrRon posted 04-11-2019 06:40 PM 1152 views 0 times favorited 38 replies Add to Favorites Watch
View MrRon's profile
MrRon
5907 posts in 3985 days
04-11-2019 06:40 PM
Topic tags/keywords: question
After spreading glue on both pieces of wood, and pressing them together; when I try to clamp them, the “slippery” glue lets the wood move out of alignment. What is the right way to clamp so they stay in alignment?
38 replies so far
View Gene Howe's profile
Gene Howe
12132 posts in 4170 days
#1 posted 04-11-2019 06:51 PM
Edge guing or face gluing? Or, something else?
View CWWoodworking's profile
CWWoodworking
713 posts in 920 days
#2 posted 04-11-2019 07:09 PM
Assuming your talking panels, use clamps on top and bottom. Tighten top ones first while pushing down on middle of bar.
View Rich's profile (online now)
Rich
5545 posts in 1331 days
#3 posted 04-11-2019 07:27 PM
For panels, use either dowels, biscuits or cauls. You can make cauls easily with 8/4 stock ripped straight and then cut to a slight arch in the middle. I have a piece of MDF that I use as a template to cut the profile on my router table with a profile bit. Also, be sure to cover the edge with something like packing tape so the glue doesn’t stick.
If you’re talking about face-to-face, a lot depends on the situation. You can get the pieces aligned and shoot a couple of 23 ga pins to hold them in place while you clamp. You can also shoot three or four 23 ga pins that are shorter than the thickness of the board into one face and clip them with diagonal cutters. The little protrusions are enough to bite and prevent slippage, but small enough not to prevent the pieces from coming together.
For right angle, it’s hard to beat dowels, although the right angle clamping guides you can buy or make help keep the edges flush.
View Aj2's profile (online now)
Aj2
2987 posts in 2539 days
#4 posted 04-11-2019 08:02 PM
I find different projects always present this challenge. Sometimes I use blocks sometimes I use blue tape or packing tape. It’s a whole separate set of skills we develop.
Good luck
-- Aj
View JohnMcClure's profile
JohnMcClure
992 posts in 1382 days
#5 posted 04-11-2019 08:08 PM
For panels, use either dowels, biscuits or cauls. You can make cauls easily with 8/4 stock ripped straight and then cut to a slight arch in the middle. I have a piece of MDF that I use as a template to cut the profile on my router table with a profile bit. Also, be sure to cover the edge with something like packing tape so the glue doesn t stick.
If you re talking about face-to-face, a lot depends on the situation. You can get the pieces aligned and shoot a couple of 23 ga pins to hold them in place while you clamp. You can also shoot three or four 23 ga pins that are shorter than the thickness of the board into one face and clip them with diagonal cutters. The little protrusions are enough to bite and prevent slippage, but small enough not to prevent the pieces from coming together.
For right angle, it s hard to beat dowels, although the right angle clamping guides you can buy or make help keep the edges flush.
- Rich
Rich,
Never thought of that trick but it sounds like a good one. I’ll have to remember that. Thanks.
MrRon,
Good thread.
-- I'd rather be a hammer than a nail
View SMP's profile
SMP
2017 posts in 647 days
#6 posted 04-11-2019 09:12 PM
for edge glue, I prefer biscuits or if its a shorter piece, just rub jointing it.
Rich
#7 posted 04-11-2019 09:46 PM
- Rich
I’m sure it’s obvious that if the pins go in flush with the board, the above trick is worthless. One good way to make sure the pins stand proud of the surface is to shoot them through a thin board, maybe 1/8” to 1/16”, laying on top of the board you want to glue. The thin board will lift off of the pins easily and there will be enough pin protruding to snip like described above.
View Andybb's profile
Andybb
2756 posts in 1345 days
#8 posted 04-11-2019 09:48 PM
Good luck
- Aj2
+1 At least for me. It seems that every time I have a technique that works the next project calls for something more innovative because the clamp is in the way or not long enough or the wood is warped more etc. Some folks recommend adding salt to the glue joint to act as an abrasive but I have yet to do that. The scariest is with plywood or veneer as there is little wiggle room before you’ve sanded past the “Oh f**k” stage and gone through the top layer of veneer.
-- Andy - Seattle USA
Andybb
#9 posted 04-11-2019 09:51 PM
Sorry. Double post.
View Bill_Steele's profile
Bill_Steele
698 posts in 2473 days
#10 posted 04-11-2019 10:41 PM
I like biscuits or loose tenons.
View pottz's profile
pottz
9544 posts in 1726 days
#11 posted 04-11-2019 11:05 PM
- Bill_Steele
+1
View Nubsnstubs's profile
Nubsnstubs
1720 posts in 2471 days
#12 posted 04-11-2019 11:37 PM
Don’t worry about. After the glue is dried, just start sanding . It’ll clean up. ............ Jerry (in Tucson)
View Delete's profile
Delete
439 posts in 1113 days
#13 posted 04-12-2019 04:27 AM
If you want to attempt to make your own clamps a set of three of these https://hobbyworkshopprojects.blogspot.com/2019/03/woods-panel-clamps.html will handle most of your edge and face gluing needs. They are unique in that they apply pressure in two directions by tightening one screw. The more pressure you apply to the glued surface the more pressure is applied to keep everything from slipping. I can’t remember where I found it but it is clearly from a late 80’s “Wood” magazine. Once three are applied and tightened you can add all the clamps you need depending on the size of your work without fear of misaligning the glue-up.
View crowie's profile (online now)
crowie
3642 posts in 2692 days
#14 posted 04-12-2019 08:30 AM
Mr Ron, I had a similar issue with the toy making.
A woodworking friend suggested I use Titebond Original and I’ve been using it ever since!
-- Lifes good, Enjoy each new day...... Cheers from "On Top DownUnder" Crowie
View ibewjon's profile
ibewjon
1557 posts in 3534 days
#15 posted 04-12-2019 09:08 AM
That is called an Equipressure clamp. The Kitts, minus the wood may still be available. I am not sure who sold them.
showing 1 through 15 of 38 replies
