Wood for a BGE BBQ cart
Forum topic by Wstein posted 04-11-2019 01:53 PM 480 views 0 times favorited 14 replies Add to Favorites Watch
View Wstein's profile
Wstein
61 posts in 2146 days
04-11-2019 01:53 PM
Topic tags/keywords: question
i am currently thinking through some ideals for a BBQ cart for my Big Green Egg. i am wondering what kind of wood to use. I have pretty much settled on white oak for the top and any shelves I put in it. But the frame is where I am stuck. I am going to paint that part so I am not worried to much about appearance of the lumber, so I was considering 4×4 and 2×4 milled down to the sizes I want. Now my question is, do I need pressure treated (non-food contact surfaces, strictly framing) or can I use regular lumber. Like I said I am planning on painting this and putting it up on casters so there will be no ground contact. I am leaning towards regular lumber as it will be sealed with paint and then under a grill cover. Thoughts from the LumberJocks guru’s out there.
-- I would offer moral support, but I have questionable morals - Me, 2005
14 replies so far
View bondogaposis's profile
bondogaposis
5401 posts in 2740 days
#1 posted 04-11-2019 01:58 PM
Treated lumber is for ground contact, I can’t see any advantage for your purposes.
-- Bondo Gaposis
View SMP's profile
SMP
1042 posts in 295 days
#2 posted 04-11-2019 02:49 PM
Personally I would probably do redwood, stained with an exterior deck/fence stain. That seems to hold up well outdoors.
View Mark's profile
Mark
1008 posts in 2364 days
#3 posted 04-11-2019 03:04 PM
I built a table for my Primo grill. I used 5/4 Cedar for the top and shelves and milled and laminated 2×4 for the frame. I did put casters on it but mine are a bit small. 21/2”min dia or larger. Mine is 7 yrs old. Might need re-finishing
but it’s still plenty strong.
-- Mark
View CaptainKlutz's profile
CaptainKlutz
1360 posts in 1883 days
#4 posted 04-11-2019 04:06 PM
Would use durable outdoor wood;
+1 Redwood
Cedar
Cypress
Ipe
Teak (great outdoors, but too expensive and pretty to cover it with paint.)
For reference, these folks have outdoor wood rating table:
https://www.woodmagazine.com/materials-guide/lumber/outdoor-lumber
View pottz's profile
pottz
5272 posts in 1373 days
#5 posted 04-11-2019 05:18 PM
i built a potting bench out of redwood several years ago and the termites are doing a pretty good job eating it so i do not recommend it. today i would probably go with ipe which is used a lot for decking,very hard and durable and with a fresh coat of oil each spring looks like new again.my second choice would be cedar but the termites will eat that too.
Wstein
#6 posted 04-11-2019 07:06 PM
I live in Florida and there is no such thing as redwood here, affordable that is. I have used cypress in the past and it is way too soft for my taste. Cedar isn’t that economical neither, the material for the frame alone would cost $150+ if cedar was used. I looked at teak and ipe, and they are MOST definitely not affordable. That is why I was looking at dimensional lumber instead.
View MrRon's profile
MrRon
5485 posts in 3633 days
#7 posted 04-13-2019 03:39 PM
Check out plastic wood decking. It has the color built in and it is weather resistant; also great for outdoor tables and benches.
View Keith Kelly's profile
Keith Kelly
324 posts in 2053 days
#8 posted 05-21-2019 07:11 PM
What about white oak for the whole thing?
-- Keith | Subscribe: https://www.youtube.com/c/KeithsTestGarage
5545 posts in 2882 days
#9 posted 05-22-2019 11:56 AM
I think you’ll be just fine with dimensional lumber if you prime it and paint it (oil based primer).
Wstein
#10 posted 05-24-2019 03:26 AM
I think you ll be just fine with dimensional lumber if you prime it and paint it (oil based primer).
- Fred Hargis
Thanks. I ended up going with SYP that I milled down from 2×10 stock so that I could get quartersawn pine vs flat sawn to help combat twisting and cupping. I used either through dowels/pins or mortise and tenon joinery. I then sealed all exposed end grain with epoxy to help prevent moisture intrusion from that direction. Then I sealed everything with a exterior sealer/primer and then put on 3 coats of GF Westminster Green Milk Paint. That was the frame and the bottom two selves. The top is white oak, quarter sawn white oak, wenge, paduck, and sapele with 3 coats of GF Outside Oil sealing it (last coat is drying as I type). I’ll post some pics up tomorrow once I get the BGE loaded into it and has been moved to my pool area.
Wstein
#11 posted 05-24-2019 03:27 AM
For cost reasons and I didn’t want to go with any nice woods since I was going to be painting the frame of the cart.
Wstein
#12 posted 05-28-2019 03:10 PM
As promised, some pictures of the completed BGE cart.
View t3steve's profile
t3steve
20 posts in 279 days
#13 posted 05-29-2019 01:40 PM
Very nice, like the added detail on the top.
View AJPeacock's profile
AJPeacock
27 posts in 1084 days
#14 posted 05-29-2019 02:25 PM
Beautiful job, I love the egg style BBQ grill/smokers. I have the cheap aluminum knockoff and it has been great for the last 4 years.
When I upgrade to the ‘real thing’, I’ll be looking back at your cart for inspiration.
AJ
