Jet 6'' Jointer, Model JJ-6CSDX setup advice
Forum topic by Castor Woodworks posted 04-08-2019 09:00 PM 345 views 0 times favorited 9 replies Add to Favorites Watch
View Castor Woodworks's profile
Castor Woodworks
86 posts in 348 days
04-08-2019 09:00 PM
Topic tags/keywords: jointer jet new tool question tip
Hey guys,
Just picked up one of these jointers! Really excited to get it up an running. Any advice for things to look for during assembly?
Thanks,
-- Castor Woodworks, https://www.instagram.com/castor_woodworks
9 replies so far
View splintergroup's profile
splintergroup
2913 posts in 1730 days
#1 posted 04-08-2019 09:51 PM
Check the tables for coplanar and be sure to pull out the locking pin for the table height adjust (small ball shaped knob) before adjusting 8^)
View syenefarmer's profile
syenefarmer
540 posts in 3588 days
#2 posted 04-08-2019 11:11 PM
I’m not trying to be flip but the Owners Manual is your friend here. Follow the directions in it and you’ll be fine.
View CaptainKlutz's profile
CaptainKlutz
1886 posts in 2002 days
#3 posted 04-09-2019 10:23 AM
+1 Jointer manuals are very thorough.
http://content.jettools.com/manuals/man_708457K.PDF
Check all adjustments starting on pg 13, plus cutter height and in/out feed tables.
View Fred Hargis's profile (online now)
5744 posts in 3001 days
#4 posted 04-09-2019 10:27 AM
Before you actually go adjusting things do this: assemble, clean, set the cutting depth, and then joint a few boards. Lay them next to each other and see how well the joint fits. If it’s dead nuts (and it may well be) you have nothing to do….or it may be as simple as adjusting the outfeed table.
Castor Woodworks
#5 posted 04-09-2019 01:07 PM
Not gonna lie….. This tip was on point! the Infeed was not moving until i figured that out lol
- splintergroup
Castor Woodworks
#6 posted 04-09-2019 01:08 PM
Yea i did this and it was slighty off. The fence was not 90 degrees. I tuned it up and its good to go.
How deep on the cuts do you guys go? 1/16?
Before you actually go adjusting things do this: assemble, clean, set the cutting depth, and then joint a few boards. Lay them next to each other and see how well the joint fits. If it s dead nuts (and it may well be) you have nothing to do….or it may be as simple as adjusting the outfeed table.
- Fred Hargis
Castor Woodworks
#7 posted 04-09-2019 01:08 PM
Thank you so much!
- CaptainKlutz
#8 posted 04-09-2019 01:21 PM
Mine has been set just slightly less than 1/16” for most of it’s life. There are times when a deeper cut is useful, but not all that often (for me).
View Bill_Steele's profile (online now)
Bill_Steele
564 posts in 2239 days
#9 posted 04-09-2019 02:24 PM
Congrats on the new jointer. I have exactly same model (straight knives) and it has performed very well for me for the last several years. I’m not sure what tools you may have for setup of the jointer, but the following have helped me to get mine setup accurately:
Oneway Multi Gauge
Veritas straightedge
The above are kinda pricey so don’t feel that you have to buy something like these to accurately setup your jointer.
