How to get comfy rounded seats for stools? Instead of flat
Forum topic by anthm27 posted 04-08-2019 06:25 AM 2486 views 1 time favorited 28 replies Add to Favorites Watch
View anthm27's profile
anthm27
1465 posts in 1644 days
04-08-2019 06:25 AM
I would like to build some low back breakfast bar type stools, instead of having the seat flat I would like to put some curved or round in the seat to make them more comfortable? Also the back could be curved.
Can this be done with a hand held router???
Here is a picture of the type of stools I have in mind.
Thanks in advance.
Regards
Anthm
-- To be a true artist one must stick to their own thought process
28 replies so far
View robscastle's profile
robscastle
6437 posts in 2738 days
#1 posted 04-08-2019 08:07 AM
Anthony, ask Cheryl if she would like to buy you something like this for Easter:-
https://sydneytools.com.au/product/arbortech-ind-fg-100-industrial-woodcarver-blade?gclid=EAIaIQobChMIyIq1l4TA4QIVVY-PCh3s
Then have a read of this blog.
I regard to using a router yes you can but you will still need to profile the parts to make them comfortable.
The arbortech or I think a kutzall will speed up the process but be aware it may cover your neighbourhood in wood snow!
Further reading if needed:- https://www.lumberjocks.com/projects/268226
Expect lotsa mess!!
-- Regards Rob
anthm27
#2 posted 04-08-2019 09:11 AM
https://sydneytools.com.au/product/arbor-tech-ind-fg-100-industrial-woodcarver-blade?gclid=EAIaIQobChMIyIq1l4TA4QIVVY-PCh3s
Expect lotsa mess!!
- robscastle
Very interesting Rob, I had a good read and see you’ve used the same technique here on the kids stools
https://www.lumberjocks.com/projects/257658 , Brilliant work.
I will at some stage pick up an arbortech and or kutzall, I,m still wondering though if I could do it with a router and some sort of a jig that takes out the susceptibility for error using the arbor tech free hand type of thing. Having said that the kids stools you did with it look very uniform indeed, almost as if it was done with a router.
I,m guessing the factories do it with CMCs
Cheers
Anthony
robscastle
#3 posted 04-08-2019 09:20 AM
Some info on the Kutzall
https://www.youtube.com/watch?v=867gCAynTtc
You can use a router to do it as I mentioned earlier, and as your still wondering I decided to go find some examples for you to take a look at, you will need to make a jig modified (obviously the ”Stock Here” is going to be huge and the radius less) for your specific profiles, something similar to this:-
https://www.lumberjocks.com/LesHastings/blog/5388
-- Regards Rob
View BlueRidgeDog's profile
BlueRidgeDog
499 posts in 313 days
#4 posted 04-08-2019 11:14 AM
I would work the backs on the bandsaw, and the seat parts before glue up on the bandsaw as well and clean up with a small plane or spoke shave. Other methods of chipping out the waste with a power tool of sorts will be messy in the extreme.
View pottz's profile (online now)
pottz
6613 posts in 1518 days
#5 posted 04-08-2019 02:36 PM
- BlueRidgeDog
+1 id say the bandsaw would be the easiest,if you have one, otherwise robs method will get it done.
View AlaskaGuy's profile
AlaskaGuy
5414 posts in 2843 days
#6 posted 04-08-2019 02:46 PM
https://youtu.be/5SveP71RLs4
https://youtu.be/6Dzde1fKSl0
https://youtu.be/wFXqQuIVetM
This one might be best for you application…....but use a dado blade in place of a saw blade and follow you line. That will get rid of a lot more waste
https://youtu.be/V3AOcthN7dg
https://youtu.be/WrzGGA79kfU
anthm27
#7 posted 04-09-2019 12:11 AM
- robscastle
Cheers Rob for taking the time to find and pass on all that info. That along with the Video links that Alaskan Guy has sent through below, I really have learnt a lot overnight, As we discussed on the phone it really seems remarkable that if used properly how accurate those kutzalls or arbotechs can be.
Thanks again
Regards
Anthony
anthm27
#8 posted 04-09-2019 12:13 AM
- BlueRidgeDog
- BlueRidgeDog
- pottz
Thanks for the input Blue Ridge and Pottz, I only wish I did have a band saw, one day I will, but here in Hong Kong I just simply dont have the room to have one set up.
Regards
Anth
anthm27
#9 posted 04-09-2019 12:15 AM
- AlaskaGuy
Thanks for taking the time to post all those links and outlining several different ways of going about it, I clicked on all the links and watched most of it , definitely learnt a lot there. Thanks again
Regards
Anthm
25767 posts in 4385 days
#10 posted 04-09-2019 02:06 AM
Anthony, you could use an ‘Arbourtec Carving Disc’ that fits on a standard grinder.
You can do serious cuts down to fine cuts then belt sand the rest.
https://sydneytools.com.au/product/arbortech-ind-fg-100-industrial-woodcarver-blade?gclid=Cj0KCQjw4qvlBRDiARIsAHme6otBC3kvyBDGs_ByYWwgSfIL3U804f9JgEtEPYkCHelx-KtXzBWuxGsaAot2EALw_wcB
anthm27
#11 posted 04-09-2019 02:38 AM
Anthony, you could use an Arbourtec Carving Disc that fits on a standard grinder.
- Grumpy
Thanks Tony , yes Interesting, I,ve been chatting to RobCastle about them also.
At the moment I,m just trying to compare the two Arbourtec products . Turbo Planer here verses The wood carver “here
Im not sure which is better, Im thinking the turbo plane is a newer product and seems to be a bit finer.
Thanks for the heads up.
Regards
Anthony
View CaptainKlutz's profile (online now)
CaptainKlutz
1935 posts in 2028 days
#12 posted 04-09-2019 10:15 AM
- anthm27
Method using a gimbal router sled to carve a curved seat platform:
https://www.popularwoodworking.com/projects/aw-extra-42414-gimbal-jig/
Cheers!
#13 posted 04-09-2019 10:27 AM
I have the turbo, it’s awesome.
AlaskaGuy
#14 posted 04-09-2019 02:29 PM
Deleted by someone.
anthm27
#15 posted 04-09-2019 10:17 PM
- anthm27
Cheers!
- CaptainKlutz
Thanks for the input Captain,
Rushing to work at the moment but will be sure to have a good research on this when I get back
Thanks again
showing 1 through 15 of 28 replies
