Angle cuts
Forum topic by Eloyd posted 04-08-2019 05:59 AM 481 views 0 times favorited 4 replies Add to Favorites Watch
View Eloyd's profile
Eloyd
37 posts in 2196 days
04-08-2019 05:59 AM
I want to make a pencil holder for my desk. I want it to be 5” tall, but I want to make it triangle shape. I divided 180 degrees by 3 to get each end of 60 degrees. However, my table saw wont go past 45 degrees. How do I cut 3 sides at 60 degrees? I have seen some 60 degree router bits, is that what I must use to cut this?
-- Eloyd
View MrUnix's profile
MrUnix
8152 posts in 3001 days
#1 posted 04-08-2019 06:08 AM
Flip it over and cut at 30 degrees
View wichman3's profile
wichman3
97 posts in 1423 days
#2 posted 04-08-2019 11:43 AM
Imagine you are ripping a 1×6 board. If the saw is set at 30 degrees and you have the 6 inch side flat on the table the cut on the 6 inch side will be 30 degrees. If the 1 inch side is against the table then the cut on the 6 inch side will be 60 degrees.
View SMP's profile
SMP
2248 posts in 707 days
#3 posted 04-08-2019 05:15 PM
Pro tip: make some test cuts with scraps to make sure you are cutting the correct angle on the correct side of each piece.
View Andybb's profile
Andybb
2784 posts in 1405 days
#4 posted 04-08-2019 06:22 PM
- MrUnix
+1
-- Andy - Seattle USA
