Project includes cutting small pieces
Forum topic by Jack Lewis posted 04-07-2019 08:32 PM 309 views 0 times favorited 7 replies Add to Favorites Watch
View Jack Lewis's profile
Jack Lewis
437 posts in 1442 days
04-07-2019 08:32 PM
I have in mind a project that will require many small irregular 3, 4, & 5 sided pieces less than 1 sq. in. ea. for a mosaic scene used for segments in a feature ring. Therefore the seams between the small pieces should fit together rather snugly. I contemplated a scroll saw but not positive the cut will finish smooth enough. I will be makings the ring from glued up blocks of about 2.5×2.5 inches.
My question is “How can I cut the small pieces safely, accurately and away from my fingers?”
Available: scroll saw (no experiencs), band saw, TS, Miter saw
-- "PLUMBER'S BUTT! Get over it, everybody has one"
7 replies so far
View John Smith's profile
John Smith
1797 posts in 527 days
#1 posted 04-07-2019 08:35 PM
belt sander ?
-- Failure is proof that you at least tried ~ now, go do it again, and again, until you get it right --
View wuddoc's profile
wuddoc
344 posts in 4082 days
#2 posted 04-07-2019 09:23 PM
We have used the Micro Mark table saw for the tiny angled feet called for on the Rockler music box plans as well as turning pen turning squares into octagons before turning.
-- Wuddoc
Jack Lewis
#3 posted 04-07-2019 10:15 PM
- wuddoc
TX, followed that idea and looked at them. They have hardwood limits too small
View sras's profile
sras
5063 posts in 3493 days
#4 posted 04-07-2019 10:32 PM
Depends on the shape, but a lot of times small pieces can be cut from longer strips of wood.
Craftsman on the lake
2959 posts in 3802 days
#5 posted 04-07-2019 10:45 PM
Cut a long section with those dimensions on a table saw then slice off pieces.
View FirehouseWoodworking's profile
733 posts in 3637 days
#6 posted 04-08-2019 01:27 AM
I would make two sleds and then use a pattern bit on the router table.
Hopefully, these pictures will depict for you what I have in mind. You can make hundreds of pieces with these and a router table.
Cheers!!
-- Dave; Lansing, Kansas
View Flights's profile
Flights
8 posts in 101 days
#7 posted 05-16-2019 03:35 AM
Great suggestion firehouse. What did you use to make the designs, google sketchup?
