Table Saw Arbor Nut not Tightening
Forum topic by dbw posted 04-06-2019 05:13 PM 911 views 0 times favorited 20 replies Add to Favorites Watch
View dbw's profile
dbw
495 posts in 2610 days
04-06-2019 05:13 PM
Topic tags/keywords: table saw table saw blade arbor nut arbor washer arbor
I have a 20 year old Jet Contractor TS with a Forrest WWII of the same age. Everything was okay until I purchased a new Freud full kerf combo blade (red coating). I went to install the new blade and now I can’t get the arbor nut to tighten. I hold the blade stationary with a piece of scrap wood and the nut, washer, arbor, belt, and motor shaft turn. I have to hold the belt with my hand in order to tighten the nut. The same situation occurs when I want to remove the blade. I returned the blade (thinking there was something wrong with it) and Rockler was nice enough to swap it for another one. No difference. The weirdest thing is now the same thing occurs with my WWII. I added two dado shims (.040 total) in between the washer and blade. No difference. I checked the nut, washer, and the arbor threads. There doesn’t appear to be any issues with any of these items. Can anyone tell me what is going on?
-- Measure twice, cut once. If you cut it too short get a wood stretcher.
20 replies so far
View Kazooman's profile
Kazooman
1540 posts in 2925 days
#1 posted 04-06-2019 05:26 PM
Sounds like there might have been some sort of coating on the Freud blade that got on the flange on the arbor and now both blades are slipping when you try to tighten the nut while holding the blade still. Try cleaning everything off with mineral spirits or something similar and try again with the WWII (clean it as well before trying).
View jonah's profile
jonah
2136 posts in 4272 days
#2 posted 04-06-2019 06:01 PM
I’m not sure I understand exactly what the problem is. Do you not use two wrenches to tighten it? With a wrench holding the arbor in place, it seems like the only way the nut would fail to tighten against the blade is if there is something wrong with the nut or flange.
View MrUnix's profile
MrUnix
8359 posts in 3172 days
#3 posted 04-06-2019 06:48 PM
Keep holding the belt or use an arbor wrench when tightening… No need to use the arbor wrench when taking it off – just use your block of wood and loosen the arbor nut as usual.
If anything, I’d give the arbor threads a good cleaning – solvent + wire brush and maybe a dash of wax.
Kazooman
#4 posted 04-06-2019 06:51 PM
I m not sure I understand exactly what the problem is. Do you not use two wrenches to tighten it? With a wrench holding the arbor in place, it seems like the only way the nut would fail to tighten against the blade is if there is something wrong with the nut or flange.
- jonah
It’s an older contractor saw. Probably doesn’t have flats for a wrench on the arbor. Normally you can spin the nut on finger tight, and when you hold the blade there is enough friction to hold the arbor in place and you can tighten the nut further with a wrench. In the OP’s case this used to work and after mounting the Freud blade when he tries to do the final tightening while holding the blade the nut and arbor both turn and the nut doesn’t tighten up.
View dbw's profile
dbw
#5 posted 04-06-2019 09:01 PM
- jonah
It s an older contractor saw. Probably doesn t have flats for a wrench on the arbor. Normally you can spin the nut on finger tight, and when you hold the blade there is enough friction to hold the arbor in place and you can tighten the nut further with a wrench. In the OP s case this used to work and after mounting the Freud blade when he tries to do the final tightening while holding the blade the nut and arbor both turn and the nut doesn t tighten up.
- Kazooman
Kazooman is correct. There are no flats on the arbor.
View dbw's profile
dbw
#6 posted 04-06-2019 09:46 PM
Per Kazooman’s suggestion I cleaned both sides of both blades and the arbor flange/washer/nut/shaft with mineral spirits. I installed the old WWII blade. No problem. I then installed the Freud blade and it would not tighten up. What the bleep is going on?
View CaptainKlutz's profile
CaptainKlutz
4004 posts in 2467 days
#7 posted 04-06-2019 10:55 PM
The Freud blade has Teflon/silicone coating, yes the red stuff. Supposed to stop pitch from sticking to blade.
Try cleaning the blade with an aggressive solvent, like chlorinated brake cleaner. It’s one of the few things that washes of silicone’s. Lacquer thinner would be by distant 2nd choice as the ketone/acetate in it are not quite as good on silicone. Aromatic hydrocarbons in MS don’t do much to silicone.
PS – have to clean the flange again too.
Best luck.
MrUnix
#8 posted 04-06-2019 11:25 PM
Try putting the arbor nut on without any blade. If you can spin the arbor by hand just by finger tightening up the nut, you possibly have some toasted bearings as well.
Kazooman
#9 posted 04-07-2019 12:22 AM
Just leave well enough alone on most of the Freud blade. Just clean the area that hits the arbor and nut. Good to go.
View Richard Lee's profile
Richard Lee
368 posts in 1748 days
#10 posted 04-07-2019 01:02 AM
Can you spin the nut on till it hits the flange with no blade ?
View dbw's profile
dbw
#11 posted 04-07-2019 08:49 PM
The saga continues. I cleaned both sides of the Freud/flange/washer with chlorinated brake cleaner. No improvement. I spun the nut on until it ran out of thread (no blade) and I was able to turn the arbor with my fingers just by tightening up the nut. Now what?
Richard Lee
#12 posted 04-08-2019 01:28 AM
What I was trying to ask is if you tighten the nut without the blade with the washer does it stop before it hits the inner flange ?
Just wondering if the nut is running out of thread with the thinner blade and is stopping before it actually tightens the blade.
I have 3 of those red Teflon coated blades and never has one spun.
Richard Lee
#13 posted 04-08-2019 01:34 AM
View Nubsnstubs's profile
Nubsnstubs
1757 posts in 2703 days
#14 posted 04-08-2019 04:22 AM
His only problem is that coating on the blade. I’ve been at this professionally for over 40 years now. I have never had a blade tighten itself until I recently bought a red Freud saw blade. I tightened it like I’ve been tightening blades all my life.
I’ll put the blade on the arbor, flange, and then hand tighten the nut. I’ll then put the wrench on the nut, let the wrench rest on the throat, and give the blade a slight pull to tighten it for cutting, about 5 lbs torque. When I went to take the thin kerf blade off buy running a board up against the teeth while using the wrench to loosen the nut, I thought I was going to put a bend in it that would make it unusable. I had to get a 1/8” piece of aluminum and put it between a couple teeth to assist loosening the nut. the torque from use had to have been over 40-50 lbs, way more than necessary. I ended up removing the paint with an orbit sander where the flange seats on both sides. The blade is now removable like all have been for the last 40 years. .............. Jerry (in Tucson)
View Woodknack's profile
Woodknack
13543 posts in 3353 days
#15 posted 04-08-2019 04:24 AM
Invite someone local to come to your shop and put the blade on.
