Rockwell 18" Wedge Bed Planer
« back to LumberJocks.com Site Feedback forum
Forum topic by motion posted 04-05-2019 11:11 AM 443 views 0 times favorited 2 replies Add to Favorites Watch
View motion's profile
motion
6 posts in 334 days
04-05-2019 11:11 AM
I recently purchased a wedge bed planer (bad shape) and am restoring it, also I’m adding a Shelix cutter head. It has a 5HP/3450 RPM’s motor. I believe the pulleys (2.625 OD / 3.875 OD) are original but not sure. I can get either 5092 RPM’s or 2337 RPM’s on the cutter head. What’s a good cutter head speed? Thanks in advance for any thoughts or comments.
2 replies so far
View hkmiller's profile
hkmiller
156 posts in 559 days
#1 posted 04-05-2019 11:32 AM
We need some pictures of this thing
-- always something
View CaptainKlutz's profile
CaptainKlutz
1746 posts in 1972 days
#2 posted 04-05-2019 12:21 PM
hmm, need more information: What is diameter of cutter head?
The key to machining anything is feed rate. Which for planer is related to both speed and diameter of cutter head.
FWIW – Commercial 15” & 20” Asia made planers typically specify a 5-6K RPM cutter head, and use a ~75mm OD head, with straight cutters protruding ~2 – 2.5mm.
Since you are working with US made Rockwell planer (22-20X?), you should be able to find information to help on http://www.vintagemachinery.org/
Best Luck.
