Temporary Walls
Forum topic by stfinney posted 04-03-2019 08:27 PM 584 views 0 times favorited 14 replies Add to Favorites Watch
View stfinney's profile
stfinney
14 posts in 603 days
04-03-2019 08:27 PM
Topic tags/keywords: wood oak wall
Hey all, I have some temporary walls using oak plywood and oak strips that I made for a local restaurant that hook to a brick wall and to each other using metal brackets made for bed rails. They work good but the only problem is that they are heavy for the servers to carry and snap back together. My question is, do you have any ideas for something better?? At the time, this was all I could think of that matched the decor. I would like to remake them using something that is lighter but still maintains some strength. They are used as a separator/barrier when eating but removed when the 2 sections are pushed together for larger parties. I would love some ideas please, thanks!
14 replies so far
View John Smith's profile
John Smith
2776 posts in 1077 days
#1 posted 04-03-2019 08:40 PM
I have seen similar restaurants that accommodate larger dining parties
without the partitions and it appears everyone has a good time.
(Golden Corral, Sonny’s BBQ, steak houses, etc.)
I would eliminate the “temporary” partitions all together if switching
them around is a problem.
how thick is the plywood ??
I would try for lighter wood like a 4” box-type cedar frame with 1/4” luan plywood skin.
it would have more bulk, sit more firmly on the floor, and when attached to the wall,
should be just as sturdy (or more) than a single panel.
(or hire bigger, stronger servers).
-- there is no educational alternative to having a front row seat in the School of Hard Knocks. --
View HackFabrication's profile
HackFabrication
172 posts in 626 days
#2 posted 04-03-2019 09:20 PM
Rather than a re-design, consider fabricating up some sort of wheeled cart to move them around on. Something like a dolly, but with casters on it. I’m thinking a seriously downsized version of what you see at Home Depot or Lowe’s that you can stack plywood into. Only need to lift them up a couple of inches (keeping them vertical), to get them on the platform and wheel them off to wherever they are stored when not in use.
-- "In the end, it's all Hack..."
View bondogaposis's profile
bondogaposis
5889 posts in 3266 days
#3 posted 04-03-2019 09:37 PM
Use frame and panel construction with 1/4” plywood.
-- Bondo Gaposis
Craftsman on the lake
3559 posts in 4352 days
#4 posted 04-03-2019 10:01 PM
- bondogaposis
Ya, what I thought.
View DS's profile
DS
3590 posts in 3335 days
#5 posted 04-03-2019 10:46 PM
It is typical, in commercial partitions, to use a corrugated core with a veneer over that.
Something like this;
It is super lightweight and really strong (>200lbs crush strength) and takes KD fasteners just fine.
On the downside, it actually costs more than traditional plywood (for the good stuff) and you have to edge it with inset lumber so your fasteners and trim will hold.
If you have an office cubicle, you have seen this product.
stfinney
#6 posted 04-03-2019 11:24 PM
Yes, it is 3/4” oak plywood right now. Per the clients request, they want to keep the walls and customers want them there. It’s a BBQ restaurant and the servers are not always in the best mood, hence the need for strength. I have no problem making a channel for something to set into, like the cardboard idea. That actually sounds really doable. I am not sure on the 1/4” plywood as the 3/4” that I have now has some good sized dents from them hitting it with the granite top tables. Also, it has to be about 50” high at the most, so custom is key.
View CaptainKlutz's profile
CaptainKlutz
3828 posts in 2409 days
#7 posted 04-04-2019 07:10 AM
+1 – if light weight is super important, use light weight core.
Honeycomb is expensive. Cheapest office furniture uses FOAM board, laminated with heavy paper for impact durability, then fabric for noise reduction.
In wood application, use 1” foam board, 1/8” luan ply skin. Edge the foam with lumber (ply on top of both, and it looks/acts like plywood barrier, except it weighs about same as 1/4 ply barrier.
- DS
View DS's profile
DS
#8 posted 04-04-2019 03:25 PM
Perhaps, a wood-grained plastic laminate on a corrugated core and trimmed with solid wood would be more durable?
P.S. Corrugated cores come in many varied thicknesses. 1 1/4” to 1 1/2” thick is common for this type of partition.
stfinney
#9 posted 04-04-2019 10:35 PM
- DS
- CaptainKlutz
I like that idea too, I am not sure why I never thought of using foam board with 1/4” plywood on both sides. They have it in oak too so it would match with what we have now.
stfinney
#10 posted 04-04-2019 10:37 PM
Another thing too, I would love to have just 1 section instead of 2, making it easier to take out and put back. Do you guys thing earth magnets would be strong enough to hold the walls in place????
View DS's profile
DS
#11 posted 04-04-2019 11:01 PM
Why wouldn’t it work as a single piece?
I wouldn’t trust magnets for this, but, I would still try to make it one piece.
View wood2woodknot's profile
wood2woodknot
109 posts in 2888 days
#12 posted 04-05-2019 02:35 AM
plastic 4’ x 8’ lattice garden panels with a fabric skin ???
-- ajh
stfinney
#13 posted 04-05-2019 02:40 AM
Why wouldn t it work as a single piece?
I wouldn t trust magnets for this, but, I would still try to make it one piece.
- DS
I am worried about their storage space. I need to keep it as small a footprint as possible. I need to see how much room they have, but I am sure it will work.
View therealSteveN's profile
therealSteveN
6645 posts in 1489 days
#14 posted 04-05-2019 02:52 AM
Something like this maybe
You need solid wood to wrap it, and give it a frame. Suppose you could cut a dado in the solid stuff to inset this panel. You could wrap it with a fabric to please the customer. Put together so it was designed to come apart you could wash or replace the fabric as needed. Guaranteed to weigh less than 3/4” Oak ply.
-- Think safe, be safe
