Decent belt sander rec's
Forum topic by AAANDRRREW posted 04-01-2019 01:15 PM 563 views 0 times favorited 9 replies Add to Favorites Watch
View AAANDRRREW's profile
AAANDRRREW
218 posts in 2055 days
04-01-2019 01:15 PM
Hi All,
I have an old black and decker belt sander from the early to mid 90’s my folks gave me. I don’t use it real often so I never had the urge to upgrade. This spring I’m going to be sanding our resonable sized deck. I am thinking of upgrading to a little better belt sander, but when looking at the prices I was surprised how expensive they are compared to my 5” RO’s.
I don’t need the best and most expensive, just a moderarly to lower priced dependable one. I am not even sure if I need variable speed – the one I use now isn’t and I’ve never had the urge to want one.
9 replies so far
6502 posts in 3376 days
#1 posted 04-01-2019 01:42 PM
I think in this case I’d consider renting one. You can get a larger unit and get done more quickly.
View GR8HUNTER's profile
GR8HUNTER
7919 posts in 1595 days
#2 posted 04-01-2019 02:05 PM
I too would rent …. here you can rent for 4 hours ... GOOD LUCK :<)))
-- Tony---- Reinholds,Pa.------ REMEMBER TO ALWAYS HAVE FUN :<))
View pottz's profile
pottz
11708 posts in 1867 days
#3 posted 04-01-2019 02:15 PM
yeah if it’s something your only gonna use for that one project rent one.
View bigblockyeti's profile
bigblockyeti
6786 posts in 2603 days
#4 posted 04-01-2019 02:21 PM
For what you’d likely spend on a rental, you’re already half way to owning a used one. I bought a Porter Cable 362 CPO for $160 15 years ago and I’ve seen them for less than half that used on CL or the like several times since. I even picked up a variable speed, like new Porter cable 3” x 21” belt sander for $10 at a garage sale. There are deals to be had and often you can own for less than the price of renting.
View PPK's profile
PPK
1802 posts in 1692 days
#5 posted 04-01-2019 04:01 PM
Variable speed isn’t necessary at all…
But they all seem to come with it anyway.
I’d buy a porter cable, they are good.
I personally don’t like renting, but it’s up to you. The porter cable sanders can be had for about $170
-- Pete
#6 posted 04-01-2019 04:29 PM
I should have said: rent, but probably not a belt sander. They almost certainly have something that would be more suited (easier, quicker) for sanding a “reasonable” sized deck. Such a job is going to tax the best hand held sander, so findng another way would be a good thing. Even if the hand held belt sander is the best tool, you will be using it a lot…burning up a rental (with hazard ins.) is much better than burning up the one (or more) you just bought. Something like a flooring sander might be a better way.
Rick Dennington
7013 posts in 4077 days
#7 posted 04-01-2019 05:19 PM
I have a Porter Cable belt sander…..3 X 21…..Had it for years….Used it twice, I think….I don’t care for belt sanders, as they can get too aggressive. You really need to know how to use one, or it can chew up the wood and make deep grooves or high and low spots on the lumber.
-- " There's a better way.....find it"...... Thomas Edison.
View Kirk650's profile
Kirk650
680 posts in 1631 days
#8 posted 04-02-2019 12:59 AM
I don’t use a belt sander for any kind of fine work. Most of what I use mine for is to clean rough wood prior to running it through the jointer and planer. Keeps the sand and dirt away from the knives.
As for which one to buy, I like my 3×21 Makita, and the 3×21 Ryobi I bought maybe 12 years or more ago simply won’t die. If Ryobi still offers a belt sander, it should be cheap and acceptable.
View Ripper70's profile
Ripper70
1378 posts in 1791 days
#9 posted 04-02-2019 02:27 AM
Save your back and your knees. Go to HD and get one of these for the day for less than $100 bucks.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
