Need a new Drill Jig
Forum topic by gmaffPappy posted 03-31-2019 02:34 PM 200 views 0 times favorited 1 reply Add to Favorites Watch
View gmaffPappy's profile
gmaffPappy
63 posts in 2419 days
03-31-2019 02:34 PM
My old Drill Jig has nearly made its last hole. It’s cheap plastic is cracked and I’m looking for something with more capability. Short of a drill press (sometimes it’s easier to bring the drill to the wood and not the wood to the drill), does anyone have suggestions on a replacement?
There’s the obvious plastic replacements from a big box store that have different sized holes for various bits, all set at 90 degrees. Some have metal drill guide inserts, which would be better. But I want something a little more versatile.
Has anyone used anything like: Wolfcraft 4525404 Multi-Angle Drill Guide?
I like the premise of being able to set angles, but this doesn’t look like it would produce accurate results.
Thoughts/Suggestions?
-- If it's easy to do, you haven't spent enough time over engineering it.
1 reply so far
View Tmanpdx's profile
Tmanpdx
23 posts in 99 days
#1 posted 03-31-2019 06:08 PM
If I’m going to bring the drill to the wood, I create a block that I drill on the drill press and then clamp that block to the piece. This ensures straight holes.
I would use that method over what you are suggesting and buy a used drill press off of craigslist.
