Bandsaw, help me decide
Forum topic by Theokwoodworker posted 03-27-2019 03:51 AM 1246 views 0 times favorited 12 replies Add to Favorites Watch
View Theokwoodworker's profile
Theokwoodworker
12 posts in 758 days
03-27-2019 03:51 AM
After years of dealing with a 9” Delta bench top bandsaw I’m ready for a real bandsaw. I am torn between
https://www.woodcraft.com/products/14-steel-frame-band-saw-13-resaw-capacity-model-jwbs14-sfx
https://www.woodcraft.com/products/laguna-14-12-bandsaw
https://woodcraft-production-weblinc.netdna-ssl.com/product_images/rikon-14-deluxe-bandsaw-model-10-326/5845cf8a69702d3a1e000351/super_zoom.jpg?c=1480970122
Jet 14” steel frame
Laguna 14-12
Rikon 10-326
I’m leaning hevily towards the rikon before I pull the trigger I’m looking for opinions especially regarding longevity, power and ease of use.
Thanks in advance!
12 replies so far
View Lazyman's profile
Lazyman
6946 posts in 2449 days
#1 posted 03-27-2019 04:10 AM
Have you looked at them in person? I don’t know if it was the rikon you are looking at but I saw a used one recently whose table just didn’t look very well finished. That would be my only concern with that one. With price being basically equal, I think I would go with the jet myself. Unfortunately, i think you may have just missed one of their 10% off sales.
View Rich's profile
Rich
6786 posts in 1651 days
#2 posted 03-27-2019 05:37 AM
I have the Rikon 10-326 and it’s a solid performer (the table is finished flawlessly), but those are all good machines, and any of them will do well for you.
View Francisco Luna's profile
Francisco Luna
1003 posts in 4455 days
#3 posted 03-27-2019 06:40 AM
I’m with Rich, have been thinking about this bandsaw, I have seen lots of good reviews….
http://www.leevalley.com/us/wood/page.aspx?p=75265&cat=1,41036,75262
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
Theokwoodworker
#4 posted 03-29-2019 12:21 PM
Well I picked up the rikon yesterday, assembly went pretty quick. Set the table and fence square did my first ever resaw with some scrap and it came out really good with just the blade it came with. I’m pretty impressed so far. I will say the stock blade seems to be trash. Watching the back side of the blade near the thrust bearing there is about 1/8” of travel. Oh well I figured I would need blades anyway.
View Steve's profile
Steve
2484 posts in 1644 days
#5 posted 03-29-2019 01:32 PM
I’m running a 1/2” Timberwolf resaw blade on my 10-326 and it cuts great.
View Rich's profile
Rich
#6 posted 03-29-2019 02:10 PM
- Theokwoodworker
What sort of travel are you talking about?
View GrantA's profile
GrantA
3107 posts in 2469 days
#7 posted 03-29-2019 02:30 PM
Yeah you do know you have to adjust the thrust bearings and guides right? Nothing should have 1/8” travel/play
Lazyman
#8 posted 03-29-2019 03:27 PM
Sounds like maybe the blade has a little kink in it?
View John Stegall's profile
John Stegall
549 posts in 4578 days
#9 posted 03-29-2019 03:42 PM
Look at Alex Snodgrass on YouTube. His Band Saw Clinic is one of the best on setting up your saw with a lot of short cuts that really produce good results. I found it to one of the easiest to understand and follow. I have an old Delta and it really learned some new tricks.
-- jstegall
Theokwoodworker
#10 posted 04-02-2019 03:31 PM
Yeah the weld on the blade is garbage, I watch the blade as it slows and it moves back and forth. I set the thrust bearing just a hair off the blade and the blade hits it right where it’s welded. Tension is good. I’ve watched the Snodgrass video probably 5 times lol. It’s a great video. There is also a ticking sound which I saw in another review video went away after putting on a quality blade.
View Rich's profile
Rich
#11 posted 04-02-2019 04:12 PM
Yeah the weld on the blade is garbage, I watch the blade as it slows and it moves back and forth. I set the thrust bearing just a hair off the blade and the blade hits it right where it s welded. Tension is good. I ve watched the Snodgrass video probably 5 times lol. It s a great video. There is also a ticking sound which I saw in another review video went away after putting on a quality blade.
- Theokwoodworker
You want to check the weld against a straightedge or flat surface. Wobbling alone is not an indication of a bad weld.
In your 10-326 user guide, at the bottom of page 27, it explains how to adjust the saw to remove back and forth blade wobble. Mine needed adjustment, and yours might too.
View Sawdust35's profile
Sawdust35
77 posts in 1924 days
#12 posted 04-02-2019 06:28 PM
OP- I have the Laguna 14bx and have been very happy with its performance so far. Have re-sawed 10” tall cherry with the resaw king blade with ease. I got the saw on sale, if Jet or Rikon had a sale back then I would have considered them as well. Good luck.
