PVC pipe to dust port?
Forum topic by BalsaWood posted 03-26-2019 11:47 PM 360 views 0 times favorited 7 replies Add to Favorites Watch
View BalsaWood's profile
BalsaWood
159 posts in 1672 days
03-26-2019 11:47 PM
Is there any type of PVC pipe that would fit directly over a 4” dust port on a table saw? Would I need an adapter of some sort? I’m assuming the dust ports on machines are standard.
7 replies so far
View BattleRidge's profile
BattleRidge
120 posts in 729 days
#1 posted 03-27-2019 12:26 AM
It might be best to connect a section of flexible 4” DC hose to the saw and then connect to the hose to the PVC. This would allow some movement in lieu of having a rigid connection. 4” DC hose seems to connect well to the machines in my shop which I then run to a blast gate at each fitting on the PVC collection pipe.
View JBrow's profile
JBrow
1368 posts in 1433 days
#2 posted 03-27-2019 03:31 AM
BalsaWood,
An option for making the 4” PVC slip over the machine 4” port is to cut 2 or 3 pieces of ¾” thick MDF glued and screw together to the outside diameter of the machine’s dust port. Using a heat gun, heat the end of the PVC 4” pipe until it softens. Then press the softened PVC pipe over the MDF die and let the PVC cool. A stick inserted into the pipe to make contact with the die and then striking the stick with a hammer will dislodge the die. I found that chamfering the edge of the MDF die makes slipping the softened PVC over the die easier. Some paste wax applied to the die’s sides helps dislodge the PVC pipe once it has cooled.
Craftsman on the lake
3020 posts in 3951 days
#3 posted 03-27-2019 04:13 AM
You can expand or shrink pvc with a heat gun or torch. I heat it, it gets soft then fit it over something then I use a stainless steel band clamp to tighten it down. It hardens at that size after it cools.
View therealSteveN's profile (online now)
therealSteveN
3916 posts in 1087 days
#4 posted 03-27-2019 05:30 AM
- Craftsman on the lake
^^^^^^This.
If it’s close with a heat gun you can make any of the assorted plastic parts fit onto another part. Hold it in place till it cools, when you pull it off it will retain the shape it cooled to. Presto Chango, parts fit. Just heat until it gets a “little” soft (PLIABLE), going overboard will get you drippy plastic. Do a test before going at something that would cost some bucks to replace. Once you have it down, like riding a bike.
-- Think safe, be safe
View WoodenDreams's profile
WoodenDreams
749 posts in 424 days
#5 posted 03-27-2019 05:45 AM
Heating the PCV tube with a propane torch or heat gun. I’ve used the torch method to soften the plastic to both expand and shrink the PCV tubes to fit over tightly. Have not required to use clamps, but I do use duct tape to help keep from slipping off once and a while.
5760 posts in 3007 days
#6 posted 03-27-2019 10:45 AM
It probably depends on the table saw. I was able to slip a PVC street L over the port on my SS, but that’s the first time I’ve had anything fit a tool with no mods.
View Redoak49's profile
Redoak49
4190 posts in 2502 days
#7 posted 03-27-2019 10:48 AM
One thing for certain is that there is no standard for dust ports or dust collection fittings.
