Delta Planer Doesn't Turn OFF
Forum topic by Parabola posted 03-26-2019 03:11 AM 222 views 0 times favorited 3 replies Add to Favorites Watch
View Parabola's profile
Parabola
16 posts in 1205 days
03-26-2019 03:11 AM
Topic tags/keywords: planer
So my delta planer stays on when powered – the switch is ineffective. It’s an older 62-185. I’m pretty green when it comes to diagnosing these, but i’m taking a guess the switch is stuck in the closed position. Any pointers before I start tearing it apart and ordering new parts? Thank you in advance. Pictures for reference…
3 replies so far
View MrUnix's profile
MrUnix
7301 posts in 2526 days
#1 posted 03-26-2019 03:22 AM
Assuming that it’s wired correctly and worked previously – just replace the switch. I personally would test the switch first with an ohmmeter/continuity meter to verify it’s bad, but that probably isn’t really needed in this case.
PS: Delta catalog #62-185 is motor (the one in the picture is #62-176), not the whole machine. The planer catalog number should be a 22-XXX type, such as 22-650, 22-651, 22-660, etc…
Parabola
#2 posted 03-28-2019 03:58 AM
Thank you – that was very helpful. I definitely wasn’t sure about the naming convention.
View SMP's profile
SMP
595 posts in 233 days
#3 posted 03-28-2019 04:10 AM
Do you have an electronic supply shop locally? Can always unscrew and bring it in. While waiting for a replacement can also unplug completely soak/spray in solvent or cleaner like simple green overnight, then flip switch back and forth a bunch of times and let dry. What usually happens is carbon buildup from the arc causes issues with the contacts or little spring loaded “arm”
