montgomeryward 10inch radial arm saw
Forum topic by cindyrose posted 03-25-2019 07:54 PM 286 views 0 times favorited 3 replies Add to Favorites Watch
View cindyrose's profile
cindyrose
3 posts in 438 days
03-25-2019 07:54 PM
I have a TCP 2610 e montgomery ward radial saw Im need help on how to remove the power cord so I can replace it. Also can someone tell me where can Iget a manual for this saw.any help is greatly appreciated.
3 replies so far
View tbone's profile
tbone
300 posts in 4425 days
#1 posted 03-25-2019 08:03 PM
I can’t help you with the power cord, but this link is for the manual.
http://vintagemachinery.org/pubs/detail.aspx?id=2981
Good luck.
-- Kinky Friedman: "The first thing I'll do if I'm elected is demand a recount."
View KTNC's profile
KTNC
161 posts in 996 days
#2 posted 03-28-2019 05:50 AM
Hi cindyrose:
I restored my TCP 2610 E in June 2018. I did not have to replace the power cord but I took a ton of pictures when I had the motor opened up. I just reviewed those and it looks like three wires come in from the power chord: white, black and green. The green one screws to the inside of the motor case and the black and white ones go to the trigger switch. I’m afraid you’ll have to remove the trigger switch and open up the motor case if you want to completely replace the power cord. Perhaps you could snip off the bad part of the chord and splice on a new section.
In my blog on the restoration you can see some pictures of the motor that might be helpful.
https://www.lumberjocks.com/KTNC/blog/122441
If you end up removing your trigger switch, don’t make the same mistake I did and diassemble your trigger switch to remove it. You just have to push a nail into the hole beside the wires to remove them. I figured that out afterwards!
The link tbone gave you above is for a TCP 2610 C. It’s very similar. I have the manual for TCP 2610 E and I’ll see if I can find a link to it for you.
regards, Kerry
View KTNC's profile
KTNC
#3 posted 03-28-2019 05:56 AM
Here’s a link to the TCP 2610 E
http://vintagemachinery.org/pubs/detail.aspx?id=2180
