Guidance Please - Shaving off 1/8 "
Forum topic by Idyllic posted 03-25-2019 04:12 PM 660 views 0 times favorited 11 replies Add to Favorites Watch
View Idyllic's profile
Idyllic
3 posts in 102 days
03-25-2019 04:12 PM
Topic tags/keywords: question
Greetings – new member – I find the LJ projects and discussions very helpful. To my issue – I created a 5 piece poplar glueup panel to insert into a rabbet cut into a headboard bed frame. The finished panel is about 1/8” too wide on the long side. The panel is 56×21 x 1/2” so it’s a bit large/unwieldy for my jobsite tablesaw.
Looking for advice – do I carefully trim it to size on the tablesaw or trading places. would you recommend using the router with a template or flush trim bit. I don’t own a tracksaw so that’s not an option. The edge will be behind the 3/8” rebbeted recess so unless I really mess up in a big way, the cut won’t be visible.
Also had a hiccup with the rabbet where I presume that I tried to remove too much stock or advanced the router in the wrong direction (maybe both) – resulted in a tearout/splintering for about 2 inches. Best to repair by applying glue and compress the material back to form (and putty/sand to hide) or remove the damage and build up a repair using wood putty exclusively. The unit will be painted.
Still new with very little experience so I look to Lumberjocks and YouTube for learning and ideas. The content you provide has been extremely beneficial.
11 replies so far
View BlueRidgeDog's profile
BlueRidgeDog
479 posts in 111 days
#1 posted 03-25-2019 04:16 PM
Do you have a hand plane? If not now would be a great time to get one. Perfect for fitting panels.
View Mosquito's profile
Mosquito
9711 posts in 2624 days
#2 posted 03-25-2019 04:20 PM
handplane would be my first choice as well, but I’ve already got a bunch and can use them well. You could use a circular saw with no track, if you have 3/8” to spare you should be able to stay in that width. You can also just use any straight edge as a guide for the circular saw, or router as well.
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View WayneC's profile
WayneC
14349 posts in 4429 days
#3 posted 03-25-2019 04:46 PM
+1 on adding handplanes to your skill set. Perhaps not for this project but in the long run it would be beneficial.
View jerryminer's profile
jerryminer
947 posts in 1773 days
#4 posted 03-25-2019 05:08 PM
Many ways to skin this cat. Easy one-minute job for a table saw with a run-out table (IMHO every table saw should have a run-out table unless your work only involves short pieces ( two feet or less). Maybe it’s time to create a run-out table?)
Hand plane, hand-held power plane, router with guide, circular saw, are all viable.
Cutting the rabbet deeper with a router would also work.
For a painted project, Bondo is better for patching than putty, as it sets up hard but is easy to sand flush.
View WoodenDreams's profile
WoodenDreams
546 posts in 243 days
#5 posted 03-25-2019 05:50 PM
I my shop I’d be using my 6”x80” edge sander to inch it down to size. A hand held belt sander will work if your comfortable with one. Plane would work
Idyllic
3 posts in 102 days
#6 posted 03-25-2019 06:12 PM
Thanks for the replies – i think cutting rabbet a bit deeper will be easiest approach. I should have figured that out since I literally had the tool in-hand to do this immediately when the issue presented. Change the bearing and pretend it was intentional (: I do have a handplane (new Stanley from Amazon) but still haven’t figured out how to get consistent results. Lots of videos on how to sharpen or rebuild but not much out there on proper technique/adjustment. The Bondo and other suggestions are much appreciated. Like any new endeavour, practice and coaching help ensure success. Thanks again
View waho6o9's profile
waho6o9
8626 posts in 2909 days
#7 posted 03-25-2019 07:03 PM
Hand saw would work as well
View them700project's profile
them700project
167 posts in 1350 days
#8 posted 03-25-2019 08:38 PM
Thanks for the replies – i think cutting rabbet a bit deeper will be easiest approach. I should have figured that out since I literally had the tool in-hand to do this immediately when the issue presented. Change the bearing and pretend it was intentional (: I do have a handplane (new Stanley from Amazon) but still haven t figured out how to get consistent results. Lots of videos on how to sharpen or rebuild but not much out there on proper technique/adjustment. The Bondo and other suggestions are much appreciated. Like any new endeavour, practice and coaching help ensure success. Thanks again
- Idyllic
came across this over the weekend
https://www.youtube.com/watch?v=QYiALzXkOWk
WoodenDreams
#9 posted 03-27-2019 05:33 AM
I’m not sure if this was suggested. youtube video by ‘Jonatha Katz-Moses’ showing how to set hand plane blades (depth and squareness). and how to test for depth and squareness. and the opening of the frog. https://www.youtube.com/watch?v=QYiALzXkOWk I see it’s been suggested.
Idyllic
3 posts in 102 days
#10 posted 03-28-2019 07:37 PM
Want to say thanks for the replies. I ratcheted up some courage and decided to learn how to use a plane (without destroying all prior work). Thanks also for the YouTube referrals – this was beneficial. Long story short, I marked the panel and used the plane to remove the excess material to that line. Worked perfectly. And I used the Bondo as suggested to fix the routing tear out. Just finished the final sand, will prime tonight and paint and topcoat tomorrow. Very appreciative to have the LumberJocks site for inspiration/guidance- I hope to be able to help others as my skills progress.
View higtron's profile
higtron
250 posts in 3009 days
#11 posted 03-28-2019 08:31 PM
A L fence with your table saw simple to make and pretty easy to make here’s a video https://www.youtube.com/watch?v=GgAZWgQCSEs
-- A friend will help you move, a good friend will help you move a body
