Pfeil marking knife kit, how to attach?
« back to Hand Tools forum
Forum topic by P89DC posted 03-25-2019 12:20 PM 385 views 0 times favorited 9 replies Add to Favorites Watch
View P89DC's profile
P89DC
21 posts in 568 days
03-25-2019 12:20 PM
I bought this Pfeil knife kit from my local Woodcraft but I can’t figure out how to fabricate a handle for it.
How do I attach the blade to a handle? I was expecting to use a couple of rivets:
9 replies so far
View John Smith's profile
John Smith
1756 posts in 493 days
#1 posted 03-25-2019 01:12 PM
how are you going to make your handles ??
you can laminate two scales together to use a brass rod as a rivet.
or – like a lot of folks do; just make your handle, drill a hole and
pour epoxy in it to hold the blade and attach a ferrule.
if you hollow out a recess between two pieces of wood, you really don’t need
a rivet – epoxy will work just fine. marking tools don’t get a lot of abuse.
-- Failure is proof that you at least tried ~ now, go do it again, and again, until you get it right --
View WayneC's profile
WayneC
14349 posts in 4428 days
#2 posted 03-25-2019 07:24 PM
Those cutters look nice.
Craftsman on the lake
2935 posts in 3768 days
#3 posted 03-25-2019 08:11 PM
- WayneC
Yes, Pfeil is good stuff. I’ve got a few carving chisels from them. I consider them some of my ‘classy’ tools. They’re also pretty pricy.
P89DC
#4 posted 03-25-2019 08:55 PM
I was going to buy a Narex off Amazon when I noticed these cutters for the same price as two Narex marking knifes. So I bought the Pfeil blades instead.
Thanks for the insight, time to make some handles from a chunk of rosewood I’ve been hauling around for the last three decades.
John Smith
#5 posted 03-26-2019 11:52 AM
P89DC – before you glue your two pieces of wood together,
if you are not sure with how you are doing, please
come back for assistance.
if you make a mistake in the assembly process – it is not the end
of the world. the blades can be cut out and another handle made.
best of luck in all your adventures.
P89DC
#6 posted 03-26-2019 02:05 PM
Hi John,
I was planning to turn a handle and drill a hole down the middle then epoxy the blade in place as per your suggestion. I might drive a brass rivet through the small hole in the blade. I don’t see the need to cut in half since the blade’s tang is so short. Thanks for all your help! I’ll be sure to follow up with pictures when I finish.
Eric
View SMP's profile
SMP
610 posts in 236 days
#7 posted 03-26-2019 03:28 PM
Thanks for posting these, I was also going to order a narex marking knife when I saw the pfeil so much more expensive. I have a horrible igaging one now that is made of potmetal that is softer than wood.
View Johnny7's profile
Johnny7
452 posts in 1421 days
#8 posted 03-26-2019 11:45 PM
From the Pfeil page at Woodcraft:
“To make your own custom marking knife, simply turn a blank and drill a 6mm (15/64”) hole and epoxy the blade in place . Flat knives can easily be made by laying up a 2-piece handle. “
View Tony1212's profile
Tony1212
309 posts in 2065 days
#9 posted 03-27-2019 12:55 PM
Hi John,
I was planning to turn a handle and drill a hole down the middle then epoxy the blade in place as per your suggestion. I might drive a brass rivet through the small hole in the blade. I don t see the need to cut in half since the blade s tang is so short. Thanks for all your help! I ll be sure to follow up with pictures when I finish.
Eric
- P89DC
I was thinking the same thing, but I came to the realization that the rivet would be right where I put my fingers. If that rivet isn’t smoothed very well, it would get rather irritating. If the manufacturer recommends just using epoxy, that’s probably the way I’d go.
-- Tony, SW Chicago Suburbs
