Finish resistant to tea.
Forum topic by AESamuel posted 03-24-2019 03:46 PM 421 views 0 times favorited 11 replies Add to Favorites Watch
View AESamuel's profile
AESamuel
105 posts in 2023 days
03-24-2019 03:46 PM
Hi there!
I’m making a small rest for used tea bags out of walnut and am now considering what finish to apply. The finish will need to be resistant to small amounts of warm water sitting on the surface, and of course the tannins from the tea. It will also be washed briefly in warm soapy water every now and again.
My first thought was simple poly or marine poly but it’s not my favourite finish to apply. Would a spray lacquer be durable enough? Is it worth putting BLO or Danish oil underneath incase there is damage to the outer finish?
Many thanks,
Asa
11 replies so far
View Woodknack's profile
Woodknack
13431 posts in 3180 days
#1 posted 03-24-2019 05:02 PM
I would be tempted to test as I’m not sure what the acids in tea will do to a finish. You could always use epoxy.
View CaptainKlutz's profile (online now)
CaptainKlutz
3320 posts in 2295 days
#2 posted 03-24-2019 05:59 PM
Tannic acid will eat thru any porous top coat, so grain needs to be filled to reduce permeation. It is also used as a yellow/brown dye component, so expect some yellowing on any polymer.
Note that all single part polyurethanes are moisture permeable (even Marine poly), and won’t tolerate extended water contact. When they absorb water, they will blush or turn white. The 2 part poly are formulated to have significantly less permeability, and perform much better than even epoxy.
IMHO – Best finish would be industrial grade 2K poly commonly used on commercial wood bar tops. Total PIA for use on small items. 2 part poly is not a offered as a consumer grade finish. Will need to obtain 2K poly from commercial supplier due Health/Safety issues.
Look for local Ilva coatings, AkzoNobel, Gemini, Sherwin Williams, PPG, or Mowhawk wood coatings distributor. AkzoNobel also sells clear Interthane 2 part poly top coat thru some marine supply stores.
MUST use all proper personal protective equipment.
Be safe!
View bondogaposis's profile
bondogaposis
5802 posts in 3152 days
#3 posted 03-24-2019 06:25 PM
I’d just use Danish oil and plan on re-oiling it from time to time.
-- Bondo Gaposis
View Andybb's profile
Andybb
2783 posts in 1404 days
#4 posted 03-24-2019 07:49 PM
I’m also thinking epoxy if you want it to be impervious to everything Mrs. Nature has to throw at it.
-- Andy - Seattle USA
View SMP's profile
SMP
2242 posts in 706 days
#5 posted 03-24-2019 07:52 PM
To be honest i would consider doing like a small inset of granite/marble. Tea will cause all sorts of weirdness and discoloration etc.
View jonah's profile
jonah
2123 posts in 4099 days
#6 posted 03-25-2019 12:26 AM
Epoxy, 100%. You need something that creates a totally impermeable layer.
I forget the brand, but there’s an epoxy bar top finish that would be a good fit here.
View Desert_Woodworker's profile (online now)
Desert_Woodworker
3035 posts in 2015 days
#7 posted 03-25-2019 12:38 AM
+1 for those who say epoxy
-- Desert_Woodworker
View SMP's profile
SMP
#8 posted 03-25-2019 03:32 AM
I forget the brand, but there s an epoxy bar top finish that would be a good fit here.
- jonah
Well there are quite a few brands. I’ve used Parks, Famowood, and another brand I forget the name of used a long time ago called Spar40 i think. Have also used some from boat store (system 3?)The famowood is probably the easiest to find.
View Aj2's profile
Aj2
3169 posts in 2598 days
#9 posted 03-25-2019 03:45 AM
Why even bother making it out of wood if your just going to cover it with epoxy. :(
Might as well be brown plastic
-- Aj
AESamuel
#10 posted 03-25-2019 03:33 PM
Thanks for the suggestions everyone, I’ll try out some of them on some test wood!
118079 posts in 4377 days
#11 posted 03-25-2019 04:04 PM
I agree with Bono
I d just use Danish oil and plan on re-oiling it from time to time.
- bondogaposis
https://www.artisticwoodstudio.com/videos
